NAS540 crashed
Space_Cake
Hello to All,
#NAS_Mar_2019
Sad news from me, the NAs540 crashed suddenly, from one day to another...
I was able to recover data from the raid, at least is not a total loss!
Current state:
- NAS540 boots
- Dos not get IP (NAS seeker says 0.0.0.0)
- Joke !
- Serial TTL, Com1,115200,N,8 and I am ready to go
- Boot up, give manual IP to egiga0
- Disable annoying buzzer
- I got to the web interface
- Login with default admin/1234
- Ask me to change password, and I change it
- Web login prompt again
- New password does not work
- Change again with more complex and longer ... nothing
- Tried 4-5 different browsers ... nothing
- "su admin" and change it then, nothing
It does not go out from change password loop.
I even tried giving him a empy hdd disk, nothing
Info:
# cat /firmware/mnt/info/fwversion
V5.21(AATB.1)
How can I change admin web password from console ?
Can I reinitialize hdd from console ?
Can I Flash with the newest 521AATB2C0 from console ?
Any help appreciated.
#NAS_Mar_2019
Yes I did reset with hw button, many times..You are aware that you only get a full factory reset when you push the button until it hes beeped 3 times? (about 20 seconds, I think).
have you tried reset your device via hw button?
Or try to reset https via console?# /etc/init.d/httpd restart0 -
Hi,thanks for the advises, I repeat, the device is already in a factory state.Yes I did reset with hw button, many times..The advice for "http restart" is misleading, it just restarts the web UI process. Yes I tried that as well.The password process still remain in the loop.0
Hi Mizelf,That did trick ! The loop is broken, I can now set a permanent admin password.Thank you!Never had a chance to tell you before, I appreciate your work on expanding functionalities of this devices ! Hope you get a breakthrough for expanding the current ones, with the current hardware they are capable for much more.Thanks again !
- 588 USG FLEX H Series
- 476 News and Release
