WRE2205 v2 Reset
gimbers
Hi All. I have three WRE2205 v2s here. One of them will reset by holding down the WPS button for 10 seconds. The other two will not, and seeing as I have no way of knowing their IP addresses, I can't login to them to reset them through the GUI. Help! Is there another way to factory reset them?
#Repeater_Mar_2019
#Repeater_Mar_2019
Press WPS button 10 seconds is the way to reset, why not try on another 2 WRE?
Here is the user manually.
ftp://ftp2.zyxel.com/WRE2205_v2/user_guide/WRE2205 v2_1.00.pdf
Thanks for the reply. I've already got the owners manual and, like I said, one will reset, but the other two won't.0
how about set up the static IP to your network card and try 192.168.1.2?
or you can check your client list in your router to check if the both WREs received the IP address from your router, then you can use the IP address to access web interface.1 -
Thanks Ijnrsi. Tried both of those. 192.168.1.2 gets nowhere and my router is not giving them an IP address. I've put them in the bin!0
Hi gimbers,
Can you share how do you connect WRE2205 v2?
Is WRE2205 v2 directly connect to your PC or ...?0
- 164 Beta Program
- 1.7K Nebula
- 86 Nebula Ideas
- 4.7K Security
- 236 Security Ideas
- 1.1K Switch
- 50 Switch Ideas
- 907 WirelessLAN
- 27 WLAN Ideas
- 5.3K Consumer Product
- 172 Service & License
- 294 News and Release
- 65 Security Advisories
- 14 Education Center
- 911 FAQ
- 399 Nebula FAQ
- 249 Security FAQ
- 90 Switch FAQ
- 100 WirelessLAN FAQ
- 18 Consumer Product FAQ
- 55 Service & License FAQ
- 68 About Community
- 51 Security Highlight
FAQ
