NAS326 - can not create new volume (create FAILED)
sander
Posts: 4 Freshman Member
I own the ZyXEL NAS 326 and I want to create a new, empty volume on one of the hard disks. I have two identical Seagate 2TB HDDs (ST2000NM0011). If put in the first one, I can easily create a new volume. If I try the same thing with the second drive, it fails.
In the ZyXEL Control Panel, under Log, I can see this message, after I tried to create a volume on it:
Now it would appear, that the drive is faulty, but this one is actually the newer one, with just 42 power-on hours. Also, SMART data shows no problem and it works normally, if I put it in my Windows 10 PC. I can format it there and store files on it with no problems.
What can I do, at least find out the real problem? The error message above says nothing. Should I connect to the NAS with SSH and check some system logs or something?
Thanks in advance for your help!
Greetings!
#NAS_Apr_2019
Greetings!
#NAS_Apr_2019
Did you change the HDD to different slot for checking if problem related to specific HDD or slot?0
Moreover, try to upgrade FW of NAS326 to latest.0
Hello Rory,
thanks for your answer. Yes, I already tried to change the slot, the problem stays the same. Changing the slot doesn't help. I can try to install the latest firmware, my current one is from late 2018, I believe. But why would this very basic function not work with the default firmware? Creating volumes on disks and saving data on them is all that this NAS was made for.0 -
I already appear to have the latest firmware:
What else can I do to get the volume created? Is there any solution? The drive is brand new.
If possible, you may change the HDD model, seems ST2000NM0011 is not in nsa326 hdd compatibility table.
https://www.zyxel.com/products_services/2-Bay-Personal-Cloud-Storage-NAS326/compatibility
But why does the other, much older, ST2000NM0011 work in the NAS without problems then?
Is there any way, to see the actual, real error message, other than "FAILED"?
Is there any official support hotline or mail address from ZyXEL?0
- 398 Beta Program
- 2.1K Nebula
- 117 Nebula Ideas
- 83 Nebula Status and Incidents
- 5.2K Security
- 99 USG FLEX H Series
- 247 Security Ideas
- 1.3K Switch
- 69 Switch Ideas
- 923 WirelessLAN
- 35 WLAN Ideas
- 5.9K Consumer Product
- 212 Service & License
- 337 News and Release
- 71 Security Advisories
- 21 Education Center
- 2.1K FAQ
- 1K Nebula FAQ
- 445 Security FAQ
- 238 Switch FAQ
- 213 WirelessLAN FAQ
- 47 Consumer Product FAQ
- 142 Service & License FAQ
- 72 About Community
- 62 Security Highlight
