VMG3625-T20A wont bridge
teksi
Hello! I am trying to bridge my ZyXel VMG3625-T20A, but it just keeps "Loading..." I already spoke to service provider, and they said I should get in touch with you guys.
So the problem is I cant bridge my port number 4, because it just shows that "Loading..." screen and wont go anywhere from there. I already waited 40minutes two times.
Also I prefer finnish, but english will do also
#SP_May_2019
#SP_May_2019
I tried with Con-Current WAN bridge thing.0
Hi teksiDo you mean you already have a WAN interface using routing mode, then you need another bridge WAN with same VLAN setting, thus you set up as concurrent WAN. And you were stuck in the con-current WAN configure page?May I ask which FW version you are testing with?0
Hi teksi ,Yes, we aware of this issue from your ISP. Now we are clarifying it. If have any update, we will inform you/ISP.0
- 588 USG FLEX H Series
- 476 News and Release
