nas326 - don´t copy (files names too long)
ruivo1973
ruivo1973 Posts: 5 image  Freshman Member
edited May 2019 in Personal Cloud Storage
Hello, i have a problem that is when i copy a photo our pdf from my computer or another computer to the nas, it says that file name is too long and do not paste the file in the nas. I´ve tried to change the name, but it says the same. It start from the photos and noe it says the same with pdf. And i cannot look for a solution. Can you help me with that?
#NAS_May_2019
  • Mijzelf
    Mijzelf Posts: 2,982 image  Guru Member
    In this case the filename is probably path+filename. Did you store the files several directories deep?
  • ruivo1973
    sometimes yes, other times no
  • ruivo1973
    it says "name too long or invalid"
  • ruivo1973
    can anyone help me?
  • hexaf
    hexaf Posts: 1
    edited June 2019
    hi ruivo1953,
    Please check your file name maybe you are using invalid character in files name.
