nas326 - don´t copy (files names too long)
ruivo1973
Hello, i have a problem that is when i copy a photo our pdf from my computer or another computer to the nas, it says that file name is too long and do not paste the file in the nas. I´ve tried to change the name, but it says the same. It start from the photos and noe it says the same with pdf. And i cannot look for a solution. Can you help me with that?
#NAS_May_2019
#NAS_May_2019
In this case the filename is probably path+filename. Did you store the files several directories deep?
sometimes yes, other times no
it says "name too long or invalid"0
can anyone help me?
hi ruivo1953,
Please check your file name maybe you are using invalid character in files name.0
- 588 USG FLEX H Series
- 476 News and Release
