[VMG8924-B10A] Router Zyxel733349
DGM
Upgraded my broadband and sent new router above.I'm used to solid lights on router when not active this unit has a permanently flashing globe since installation 2 weeks ago. ISP says that's normal are they right?
#SP_Jun_2019
#SP_Jun_2019
Do you know its model name? It calls Zyxel733349?0
Zyxel 733349 is model number that comes up on my wifi0
Okay... But I couldn't find this model from the Internet...
Can you share its firmware version?0 -
Thanks for comment I could not find the model listed either. I still have the box somewhere I'll look up the label. Appreciate your reply.
The model on box shows VMG 8924 B10 A followed by C8544B733349. It could be firmware, going to check with ISP. Regards.1
Hi DGM,
May I know who is your service provider? If you would like to know firmware version, you can login to GUI and go to status page to check it.
Below is LED behavior of VMG8924-B10A
- 164 Beta Program
- 1.7K Nebula
- 86 Nebula Ideas
- 4.7K Security
- 236 Security Ideas
- 1.1K Switch
- 50 Switch Ideas
- 907 WirelessLAN
- 27 WLAN Ideas
- 5.3K Consumer Product
- 172 Service & License
- 294 News and Release
- 65 Security Advisories
- 14 Education Center
- 911 FAQ
- 399 Nebula FAQ
- 249 Security FAQ
- 90 Switch FAQ
- 100 WirelessLAN FAQ
- 18 Consumer Product FAQ
- 55 Service & License FAQ
- 68 About Community
- 51 Security Highlight
FAQ
