I have the NSA 325 V2 and placed raid1 on disk1 while disk2 had not yet a volume
And what is the output of e2fsck?
Mijzelf:# e2fsck.new -f /dev/sdc
e2fsck 1.41.14 (22-Dec-2010)
e2fsck.new: Superblock invalid, trying backup blocks...
e2fsck.new: Bad magic number in super-block while trying to open /dev/sdc
The superblock could not be read or does not describe a correct ext2
filesystem. If the device is valid and it really contains an ext2
filesystem (and not swap or ufs or something else), then the superblock
is corrupt, and you might try running e2fsck with an alternate superblock:
e2fsck -b 8193 <device>e2fsck.new -b 8193 /dev/sdc
Ok. So e2fsck thinks there is no ext filesystem starting at zero. So let's try to assemble the array, and e2fsck that.
<div>mdadm --assemble /dev/md3 /dev/sdc --run</div><div>e2fsck.net -f /dev/md3</div>
(BTW, the difference between this array and the original one is that this one has plenty of room after the filesystem)0 -
~ # mdadm --assemble /dev/md3 /dev/sdc -- rune2fsck.net -f /dev/md3
mdadm: /dev/md3 has been started with 1 drive (out of 2).
Oops. sorry, this stupid forum glued my two command together. It was
mdadm --assemble /dev/md3 /dev/sdc --run<br>e2fsck.new -f /dev/md3
apparently mdadm wasn't upset about the extra arguments, according to it's output. So time for the 2nd command.If that succeeds you can mount the disk<div>mkdir /mnt/mountpoint</div><div><br></div><div>mount /dev/md3 /mnt/mountpoint</div>
~ # mkdir /mnt/mountpoint
~ # mount /dev/md3 /mnt/mountpoint
mount: wrong fs type, bad option, bad superblock on /dev/md3,
missing codepage or helper program, or other error
In some cases useful info is found in syslog - try
dmesg | tail or so
Mijzelf: after the assemble command this is the picture in the NAS. (see attachment)So maybe i should restart the NAS to get back the situation before the assembling.0
Did you run e2fsck on md3?About that extra disk in the GUI, I wouldn't bother. The GUI is not designed to show 3 internal disks. And I think this thing is assumed internal because it's an assembled raid array.Have you checked if the firmware already mounted md3?
cat /proc/mounts
Mijzelf: This is the result:~ # cat /proc/mounts
rootfs / rootfs rw 0 0
/proc /proc proc rw,relatime 0 0
/sys /sys sysfs rw,relatime 0 0
none /proc/bus/usb usbfs rw,relatime 0 0
devpts /dev/pts devpts rw,relatime,mode=600 0 0
/dev/mtdblock8 /zyxel/mnt/nand yaffs2 ro,relatime 0 0
/dev/sda1 /zyxel/mnt/sysdisk ext2 ro,relatime,errors=continue 0 0
/dev/loop0 /ram_bin ext2 ro,relatime,errors=continue 0 0
/dev/loop0 /usr ext2 ro,relatime,errors=continue 0 0
/dev/loop0 /lib/security ext2 ro,relatime,errors=continue 0 0
/dev/loop0 /lib/modules ext2 ro,relatime,errors=continue 0 0
/dev/ram0 /tmp/tmpfs tmpfs rw,relatime,size=5120k 0 0
/dev/ram0 /usr/local/etc tmpfs rw,relatime,size=5120k 0 0
/dev/ram0 /usr/local/var tmpfs rw,relatime,size=5120k 0 0
/dev/mtdblock4 /etc/zyxel yaffs2 rw,relatime 0 0
/dev/md1 /i-data/3cc8587e ext4 rw,noatime,barrier=0,data=writeback,usrquota 0 0
/dev/md1 /usr/local/apache/web_framework/data/cache ext4 rw,noatime,barrier=0,data=writeback,usrquota 0 0
/dev/mtdblock4 /usr/local/apache/web_framework/data/config yaffs2 rw,relatime 0 0
/dev/md1 /usr/local/apache/htdocs/adv,/res/imdb_poster ext4 rw,noatime,barrier=0, ,data=writeback,usrquota 0 0
/dev/md1 /usr/local/zy-pkgs ext4 rw,noatime,barrier=0,data=writeback,usrquota 0 0
/dev/md1 /etc/zyxel/zy-pkgs ext4 rw,noatime,barrier=0,data=writeback,usrquota 0 0
/dev/md1 /usr/local/apache/htdocs/adv,/pkg ext4 rw,noatime,barrier=0,data=writeb ack,usrquota 0 0I can't see a md30 -
Mijzelf:I have done e2fsck on /dev/md3~ # e2fsck.new /dev/md3
The filesystem size (according to the superblock) is 244061232 blocks
The physical size of the device is 244061198 blocks
Either the superblock or the partition table is likely to be corrupt!
Abort<y>? no
/dev/md3 contains a file system with errors, check forced.
Pass 1: Checking inodes, blocks, and sizes
Pass 2: Checking directory structure
Pass 3: Checking directory connectivity
Pass 4: Checking reference counts
Pass 5: Checking group summary information
/dev/md3: 93128/61022208 files (6.8% non-contiguous), 141480464/244061232 blocks~ # mkdir /mnt/mountpoint
mkdir: can't create directory '/mnt/mountpoint': File exists
dmesg | tail or so
- 220 Nebula Ideas
- 607 USG FLEX H Series
- 482 News and Release
