Multi X nodes
cjp
How many devices can you have in the mesh? Not clients but the Multy X devices themselves. Also is there an external device?
#MultyX_Jul_2019
#MultyX_Jul_2019
Multy series don't support outdoor environment.
However, there are few options for outdoor mesh AP.
WAC6552D-S, WAC6553D-E.
https://www.zyxel.com/products_services/802-11ac-Dual-Radio-Unified-Pro-Outdoor-Access-Point-WAC6550-Series/overview
Both of them need to use PoE to provide the power, please read all the spec of this product before you purchase it.
WAC6553D-E.
It provides an Embedded heater for harsh weather.
This product will require external antennas for extending the signal range.
https://www.zyxel.com/products_services/2-4-5-GHz-Indoor-Outdoor-Antenna-Antennas-and-Cables/specification
@cjp
You can find the answer in this discussion.
https://homeforum.zyxel.com/discussion/1411/will-multi-handle-6-nodes
You can also add a Multy Mini in Multy X System.
Multy Mini only can expand Multy X WiFi system for additional WiFi coverage. And it must be the last one node in Multy X WiFi System.
https://www.zyxel.com/products_services/Multy-Mini-Dual-Band-WiFi-System-Add-on-Multy-Mini/
Eric, thank you that helps. Is there an outdoor version?
Boa tarde tudo tranquilo? Estou com um zyxel WAC6553D que retirei da caixa agora a pouco comprado novo junto com outros do mesmo modelo, porém esse eu tenho resposta de pingno ip padrao 192.168.1.2, acesso ele via SSH e via terminal, ja resetei e não consigo acessar ele pelo navegador para configurar. Ja testei em outros computadores e ate mesmo com outros navegadores.0
@Leoni
If you have any questions about WAC6533D, please post your question on Biz Forum.
https://businessforum.zyxel.com/categories/wlan
- 164 Beta Program
- 1.7K Nebula
- 86 Nebula Ideas
- 4.7K Security
- 236 Security Ideas
- 1.1K Switch
- 50 Switch Ideas
- 908 WirelessLAN
- 27 WLAN Ideas
- 5.3K Consumer Product
- 172 Service & License
- 294 News and Release
- 65 Security Advisories
- 14 Education Center
- 911 FAQ
- 399 Nebula FAQ
- 249 Security FAQ
- 90 Switch FAQ
- 100 WirelessLAN FAQ
- 18 Consumer Product FAQ
- 55 Service & License FAQ
- 68 About Community
- 51 Security Highlight
FAQ
