Shared Folder lost - how to delete this entry?
MrMister
MrMister Posts: 2  Freshman Member
edited July 2019 in Personal Cloud Storage
I have connected USB-DockingStations on the Rear USB. One DS is broken so I had to change it to use the same HDD in it.
Now I see that this share is lost ("Verloren") and I cannot use this name (HDD48) again.
How can I delete this entry? I used the Delete-Button and did 2 Reboots, but no Chance.
It's a NAS326 with the latest Firmware V5.21(AAZF.3)
Thank you for your Help.
Best regards,
MrMister
#NAS_Jul_2019
  • eozrocwd
    eozrocwd Posts: 58  Ally Member
    Do you try to use "Permanently delete"?
    If connected to another USB port of NAS326, then do again "Permanently delete"?
  • MrMister
    Thanks, I didn't dare, but the tip worked.
