NAS326 Frage zu Entware, Meta-Repository
2»
  • Roggenkeil
    Roggenkeil Posts: 6 image  Freshman Member
    No, FFP is not installed (but it was once before). opkg is working when I use the command with the path, so it should be ok. Thank you so far!
  • Mijzelf
    Mijzelf Posts: 3,049 image  Guru Member
    The profile-hook package is supposed to inject some code in /etc/profile:
    [ -t 1 -a -f /opt/etc/profile ] && . /opt/etc/profile # Entware Hook
    This will add the contents of /opt/etc/profile to the environment of a shell user. Is this line present?
  • Roggenkeil
    Seems to work now! Thanks! :)
