Entware-ng install error on NSA325v2
2»
  • Mijzelf
    Mijzelf Posts: 3,042 image  Guru Member
    The simple fact that I wrote a package to install Entware-ng on a ZyXEL, doesn't make me an expert of all provided Entware-ng packages, of course.
    The only sane answer I can give you is that the firmware won't use your Entware-ng php packages, as they are on the wrong place. (in /opt/bin/, I think, while the firmware uses /usr/local/zy-pkg/bin/). So if you want to use php7, you'll have to install your own webserver either.
    MariaDB is another story, as it will conflict with MySQL (same socket). So to use it you'll have to use a non-standard socket (no idea how), or uninstall/disable the php/MySQL zypkg.
  • Teessider66
    Teessider66 Posts: 10 image  Freshman Member
    OK, thanks for all your help, I can now have a look the uipgrades.
    Cheers
  • Teessider66
    Sorry, I thought I had posted a reply.  Thank you very much Mijzelf for your help.  I'm back up and running, I'll look at getting the other stuff running.
    Thanks again!  You're a star
  • Mijzelf
    You did. But somehow you also marked it as 'Accepted answer', and that's enough reason for this stupid forum to change the sequence of the posts.
