Zyxel LTE4506
Staibisser
I need a auto start for the LTE4506.
If power down then I don't like to press the on button.
Would be nice, if this can implemented.
#LTE_Mar_2019
Thx.
chrig
#LTE_Mar_2019
Hi Staibisser,
This feature is implemented in newer hardware version. It cannot support by software design. You can provide serial number of your device and then I can check your hardware version.
Hi, Could you check this serial ? S162Z420015830
Hi Bob,
The serial S162Z42001583 is the first hardware release, which does not support auto restart.
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 482 News and Release
