Deactivate Aishield
tomasstrandberg75
Hi
I have a trial version of ai shield. How do i deactivate it?
#MultyX_Sep_2019
#MultyX_Sep_2019
Dear @tomasstrandberg75,
Please refer to below FAQ link for AiShiled.
https://homeforum.zyxel.com/discussion/1327/does-aishield-service-offer-a-free-trial/p1?new=1
Please give it a try, it will provide the extra protection for your devices, and you can also monitor your daily network usage.
https://homeforum.zyxel.com/discussion/2700/multi-x-v2-20-aisheild-deleted-my-profiles#latest0
https://homeforum.zyxel.com/discussion/2700/multi-x-v2-20-aisheild-deleted-my-profiles#latest0 -
Hi, my free trial period is now over, i only want to use parental control in the multy app, how do i do that?2
Hi @Lomprayah,
After the license expired, the frontpage of AiShield will have a renew button, please click it, and check the license of you AiShield actually expired.
Then, back to the Multy App, the parental control button should be able to click. If the button cannot click, please refresh the app.
If you have multiple Multy Sites, please click "Switch Site" on the Menu of Multy App, then click "Connect", it can help to refresh all Multy Sites.
Thanks, now it works i must have tried 1 day to early.2
- 588 USG FLEX H Series
- 477 News and Release
