LTE Ally app for iOS
AnjanM
Just newly bought the LTE router. I have trouble to find the app in the Apple App Store.
Has anyone faced similar issues and how to solve it?
#SP_Sep_2019
#SP_Sep_2019
Hi AnjanM,
You can use the keyword "lte ally" to search the app.
May I know which country/region you set on your App Store settings?
You may refer to the following instructions to check the country/region.
https://support.apple.com/en-us/HT201389
Also may I know which LTE router did you buy?
Regards,
Bob0 -
While finding a developer, qualification, or degree in a relevant area is essential. Then consider their experience, pay close attention to their projects and portfolio. Although, the developer should have a command of native languages, including Objective-C and Swift, and should be an expert in coding. Plus, the developer should have market knowledge. An app developer should be excellent at developing an app and managing time. You can go for the freelance developers as well as the companies that provide the best iOS application development services.
- 588 USG FLEX H Series
- 476 News and Release
