AP firmware synchronize cloud server failed
PPBT
PPBT Posts: 3
edited April 2021 in Security
What is it about ?
«1
  • PPBT
    PPBT Posts: 3
    AP firmware download failed. Reason: Device storage is not enough.
    AP firmware download failed. Reason: Device storage is not enough. File name:wtpinfo.
    AP firmware synchronize cloud server failed.
  • Zyxel_Charlie
    Zyxel_Charlie Posts: 1,034
    @PPBT
    To analyze this case,
    could you private message  the details of remote access  to me for checking further. (ex: SSH or teamviewer)
    Charlie
  • i'm also have seem trouble
    how to fix it?
  • Zyxel_Stanley
    Zyxel_Stanley Posts: 1,296
    100 Answers 1000 Comments Friend Collector Fifth Anniversary
    Hi @itghost1978
    Can you share firmware upgrading history on your device?
    And I will send you private message for check this issue more detail.
  • Same thing here, wtpinfo (whatever that is) will not fit in memory.
    Upgrade history = brand new ZyWall 310 straight out of the box, no upgrades done ever. Running the latest V4.31(AAAB.1) released 2018-4-11 firmware.
    Yes, the licenses have all been activated. Flash usage is 64%. Memory usage is 21%
  • Zyxel_Charlie
    @Uncle_Bob
    Regarding this case,
    Charlie
  • c7ic
    c7ic Posts: 4
    Please help!! I've the same problem.
    device - usg60w, auto upgrade - disabled
  • Zyxel_Stanley
    Hi @c7ic
    Can you upgrade USG firmware to 4.33WK19 first.
    ftp://ftp.zyxel.com/USG60W/firmware/433AAKZ0ITS-WK19-r88384.zip
    And try to enter this command to flush memory.
    Router> debug system _disk-cleanup
    After cleared memory, and try to download AP firmware again.
  • c7ic
    c7ic Posts: 4
    How I can download AP firmware manually?
  • Zyxel_Stanley
    Hi @c7ic
    You can go to Configuration > Wireless > AP Management > Firmware. Click Check button.
    It will check the latest AP version on server.
    And then click Apply button.
    If device is controlling AP, then device will download AP firmware to system first and apply to your AP.
Security Highlight
