[Transmission-Daemon] Remove torrent after completed
kimme
Hi All!
As the title says:
Would it be possible to remove a torrent file after it's completed?
I checked that the settings.json is located at /i-data/4ebe74b4/.PKG/Transmission/config/Transmission.
However when I try to access it, the permission is denied and the file shows empty.
After trying "chmod u+rwx" it gives "Operation not permitted".
Any ideas?
Thanks in advance!
Kim
#NAS_Oct_2019
As the title says:
Any ideas?
Thanks in advance!
Kim
#NAS_Oct_2019
I think you'll have to stop transmission first, before editing the file.
In a shell you can execute 'ps' to see all running processes, and look if transmission is running.How are you trying to edit the file? What is the output of
ls -l /i-data/4ebe74b4/.PKG/Transmission/config/Transmission/
thanks for the reply.
using vi to edit.
Requested output:-rw-rw-rw- 1 root root 8 Oct 18 18:12 Transmission
drwxrwxrwx 2 root root 4096 Jan 21 2019 blocklists
-rw------- 1 root root 430 Oct 18 18:05 dht.dat
drwxrwxrwx 2 root root 4096 Oct 18 17:45 resume
-rw------- 1 root root 3734 Oct 18 18:12 settings.json
-rw------- 1 root root 162 Oct 18 17:46 stats.json
drwxrwxrwx 2 root root 4096 Oct 18 17:45 torrents
Only root is authorized to edit that file. So you have to login as root.
ah ok thanks!
in the meantime I was also able to solve the issue in another way but either way it's a great tip!0
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 482 News and Release
