My Multy X unit is showing a red >, not sure what to do?
Tilly
The issue arose after the main router was reset. Also, can't get to connect to my network using iOS app....keeps saying "Connecting...."
#MultyX_Oct_2019
#MultyX_Oct_2019
Hi @Tilly,
1. What color of the LED light on the Multy?
2. What's the network topology of your Multy?
3. Did you re-install the all system after the reset?
4. If you reset the Multy by pressing the reset button, the Multy Site on Multy App won't work anymore, you will have to delete the Site, and create a new site to install the Multy.
Hi Eric
I have an EE router (fibre broadband) from which I run a cat cable directly to the first Multy X shown above. I then a have a second Multy X that is wirelessly connected to the this one. I use the app to manage but it won'[t connect as shown below (all the speed test, network topo etc. are greyed and cannot be selected).
When everything is working, I have two WRE6606 wifi extenders to connect my two laser printers on the same network.
I did not reinstall the system.
I did not press the reset button on either of the Multy X units.
Thanks,
Tilly0 -
Hi @Tilly,
Is the Multy root or extender on the picture?
If it is root, you should plug the cable on the WAN port but not the LAN port.
Please let me know if it is the cause.
- 164 Beta Program
- 1.7K Nebula
- 86 Nebula Ideas
- 4.7K Security
- 236 Security Ideas
- 1.1K Switch
- 50 Switch Ideas
- 908 WirelessLAN
- 27 WLAN Ideas
- 5.3K Consumer Product
- 172 Service & License
- 294 News and Release
- 65 Security Advisories
- 14 Education Center
- 911 FAQ
- 399 Nebula FAQ
- 249 Security FAQ
- 90 Switch FAQ
- 100 WirelessLAN FAQ
- 18 Consumer Product FAQ
- 55 Service & License FAQ
- 68 About Community
- 51 Security Highlight
FAQ
