Modem Zyxel VMG1312-B30B wifi lights but no signal
TomasTopek
Posts: 10 Freshman Member
I use wifi modem Zyxel VMG1312-B30B. Internet works perfectly only by LAN connection. Wifi lights green but no signal. I tried to reset modem, I tried instal the newest firmware, but still no wifi signal. Modem diagnostic say wlan passed - connection is OK, but still no signal. Could you please help me ? Thank you and best regards, Tomas Topek
#SP_Nov_2019
#SP_Nov_2019
Best Answers
WLAN lights green, but no signal is visible on my mobile phone, PC, atc. Please help me.
WLAN lighting green - but no wifi signal
Wireless connection test passed succesfully, but no wifi signal !!!0
Wireless connection test passed succesfully, but no wifi signal !!!0 -
Wireless setting is OK, I think, but no visible wifi signal !!!0 -
Zyxel VMG1312-B30B actual settings.
@TomasTopek,Does it mean you can not see the SSID when trying to connect the wireless network?If it doesn't work after you reset the device, my suggestion is to contact the local support.0
@Hummel,
Yes you are right I cannot see SSID. Something is wrong with Zyxel VMG1312-B30B and I don't know what ..... Therefore I'm here and I do believe that somebody help me.0 -
@Hummel,
Yes, I tried all channels, but without any success.0 -
@TomasTopek,
My suggestion is to contact your local support for the help because it looks doesn't like a problem which can be solved from the forum since you have tried to reset the device and upgrade to the latest firmware but failed to make it work.
- 415 Beta Program
- 2.5K Nebula
- 152 Nebula Ideas
- 101 Nebula Status and Incidents
- 5.8K Security
- 296 USG FLEX H Series
- 281 Security Ideas
- 1.5K Switch
- 77 Switch Ideas
- 1.1K Wireless
- 42 Wireless Ideas
- 6.5K Consumer Product
- 254 Service & License
- 396 News and Release
- 85 Security Advisories
- 29 Education Center
- 3.6K FAQ
- 76 Security Highlight
