[Zyxel VMG8924-B] I’m not able to set WPA password for my guest WiFi network
private
Hi, I think my model is this one: https://www.zyxel.com/it/it/products_services/Dual-Band-Wireless-AC-N-VDSL2-Combo-WAN-Gigabit-IAD-VMG8924-B-Series/
Firmware version is: V5.13(ABLZ.1)b8_20190225
As I said, I can set a guest WiFi with WPA2-PSK but not with WPA/WPA2-PSK. The password form doesn’t show up.
I think it’s a bug, but I could be wrong. What can I do?
#SP_Oct_2019
#SP_Oct_2019
I think it's a VMG8825, given the firmware version.
The manual says you can use "No Security" or "WPA(2)-PSK"0 -
Hi, thank you for your reply. I thought I would get an email...Mhm what do you mean? The WPA/WPA2-PSK option is there. And I need it because I want an old device to connect to it. But as I said, I cannot set a password but event more important, I cannot click the “OK” button. So I cannot save the changes. Instead I am obliged to select the WPA2-PSK only mode...0
I have VMG8823, but they have quite the same interface; I can choose only between "no security" and "wpa2-psk" (no wpa-only option).
Maybe it was available in the previous firmware, but I'm not sure.0
- 164 Beta Program
- 1.7K Nebula
- 86 Nebula Ideas
- 4.7K Security
- 236 Security Ideas
- 1.1K Switch
- 50 Switch Ideas
- 907 WirelessLAN
- 27 WLAN Ideas
- 5.3K Consumer Product
- 172 Service & License
- 294 News and Release
- 65 Security Advisories
- 14 Education Center
- 911 FAQ
- 399 Nebula FAQ
- 249 Security FAQ
- 90 Switch FAQ
- 100 WirelessLAN FAQ
- 18 Consumer Product FAQ
- 55 Service & License FAQ
- 68 About Community
- 51 Security Highlight
FAQ
