Connection issues after newest FW (v2.10(ABKJ.8)C0) for Multy X
I have same problem as Tomas. Wi Fi was screaming fast but last few months or so very patchy. It still can be fast but very often just barely acceptable. This applies to wi fi only any devices connected via Ethernet have no issues. Biggest frustration here that all was fine for almost a year and then updates came...0
Hi @gedas3 ,
We received your feedback, we will contact you directly via Email.0 -
@jb68
Let me clarify the issue, hope I don't misunderstand it.
When this issue occurred, both Multy were solid white light(normal). The only issue was when you close to the second Multy, and the connection still remained but the internet would drop suddenly.
However, it had no issue when you close to the root Multy.
So you have to reopen the wifi from your iPhone to get the internet from the second Multy.
You can check the "Diagnose" Page on the Multy App, make sure the connection between "internet to nodes" and "node to node" still work.
You can also check the Device page, if there is another phone connected to wifi but without internet, check the device information,is it connected to 5G or 2.4G.
Have you ever reboot the second Multy, or change the place of the second Multy, close to the root Mutly? It may help.0 -
Is this problem solved with last firmware?
Hi @j1simon,
Most of the issues are the backhaul connection between Multys, and it might relate to environmental interference, the distance between each Multy, and the upgrading order of each units during the process of firmware upgrading.
Please let us know If you had occurred any issue during your Multy usage, and we will glad to assist you.
You can always use the "Send Feedback" button on Multy App to contact us.
Same problem here. Any suggestions? I have three Multy X's in the house and it's happening on a daily basis. The two satellites are losing the connection and starts to make this hiss noise. I then have to restart everything and it gets back to normal. But then it happens again the next day..0
Dear @Thielst
We have received your feedback from Multy app, and we will contact you via email.
Best regards,
Jerry
- 213 Nebula Ideas
- 550 USG FLEX H Series
- 341 Security Ideas
- 295 Service & License
- 469 News and Release
