Does Multi X work well with symmetrical 1000 Mbps connections?
j1simon
I'm currently using a mesh wifi system very similar in hardware level to Multi X but with which I'm having speed problems.
#MultyX_Nov_2019
My ISP recently upgraded my connection speed from 500 to 1000 Mbps symmetrical and that's where my problems started.
The speed test integrated in the router's web interface shows speeds close to the one contracted. However, if I run the speed test on my computer (connected by cable to the router) it always gives values around 400-500 Mbps. 50% or less of the contracted speed!
I suspect the problem is a deficient QoS, integrated into the router firmware, which cannot be disabled or configured by the user.
I explain all this because if the manufacturer of my router does not solve this problem before this Black Friday, I'm thinking of replacing it with a Multi X. I need to know the experiences, opinions and problems of Multi X users to decide whether or not to buy it.
Thank you. Greetings.#MultyX_Nov_2019
Another 2 questions:
- Is it possible to control Multy X from a web interface with advanced options? Generally mobile applications to control mesh systems are basic.
- Does it allow you to change the wifi channel to select the least saturated one? I know that it usually works with "Auto" and supposedly the router selects the best channel but this is not always the case.
Dear Sir,Multy X is able to support 1G throughput from the ISP.
FYI,
1. Multy X only supports App management.
2. Multy X will detect the environment and select the best channel when it boots up, so Multy only supports auto channel select.
For more Multy X information, please refer to the FAQ of Multy X:
https://homeforum.zyxel.com/categories/faq-multy
We also provide a security solution for the Multy X users, it's AiShield.
You can get a 30-day free trial of AiShield for your first try, it will provide extra protection on your Network.
For more information of AiShield, please visit Here.0 -
that is my question too
Hi @freddrichsigh
Multy X will require a smartphone to install the Multy system and manage it with Multy App.
Please refer to the FAQ:https://homeforum.zyxel.com/discussion/154/does-multy-x-have-a-web-interface-for-configuration#latest
- 588 USG FLEX H Series
- 477 News and Release
