Locked out of VMG3925-B10C
Chewi
I may have done a bad thing. I have the VMG3925-B10C. It was on firmware V5.13(AAVF.12)C0. The 5GHz wi-fi had been cutting out once every couple of days or so. I had seen around here that the B10B has possibly had this fixed in a newer firmware and I gathered they use the same firmware anyway so I thought I'd try that. I knew that the upgrader at least had a basic model check.
It got stuck in the self-test for ages with the power LED blinking green. After at least 10 minutes, I gave up waiting and used the factory reset button. It thankfully did come back. I can access web UI, SSH, telnet, and FTP interfaces but the "default" login doesn't work at all! I've tried all sorts but I'm completely locked out. This includes:
#SP_Nov_2019
- My original login
- admin/1234 (which is printed on the back)
- admin/admin
- admin/password
- admin/<blank> (web UI doesn't allow it at all, others reject it)
#SP_Nov_2019
I should add that the version I've upgraded to is V5.13(AAVF.13)C0. It does say VMG3926-B10A/VMG3925-B10B/VMG3925-B10C Generic at the top of the release notes and it still says B10C on the login page so even though this firmware wasn't explicitly listed as a B10C download, it seems like this should still work. The password issue may be unrelated.0
- 588 USG FLEX H Series
- 477 News and Release
