NAS542-4 - In Raid 1, use diffrent disk brand
Erike30
Hi.
In NAS 542-4
Can i mount 2 different disk brand(same spec) in raid 1
Both in are on the compability list.
Model: WD40EFRX
Capacity: 4TB
Capacity: 4TB
#NAS_Nov_2019
In NAS 542-4
WD Internal drive Red
Model: WD40EFRX
Capacity: 4TB
Seagate Ironwolf
Model: ST4000VN008Capacity: 4TB
#NAS_Nov_2019
The brand doesn't matter, however these two disks has different rpm, it may cause performance reduction. Mixing 5400 rpm and 5900 rpm works, but it's not optimal for obvious reasons.
@Wiasouda: Do you have proof for that? It made me think, at first sight it seems obvious, but AFAIK the disks are not synchronized. So when a sector has to be accessed on both disks, they won't arrive at the same time anyway, as the disks don't have the same rotational angle. So does the difference in rpm really matter?
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
