Zyxel326 lost settings after reboot and other
nikolae
NAS Zyxel 326, don't know what version of linux is installed:
Linux storage 3.10.39 armv7l GNU/Linux
I have ssh access and after logon I see this message:
BusyBox v1.19.4 built-in shell (ash)
First I notice that, when I made some changes - crontab, edit config file, after nas reboots, changes are lost.
Is there any way to prevent this or somehow to put my settings at system startup?
For example I would like to use daily reports for my hdd smart status.
I make script to receive report and put in to crontab
I make registration in maiiljet for this purpose. Everything works fine.
From other side, when nas is rebooted it's remember settings - disk volumes, ip's, users and etc...
I found this file, where there is a lot of options setting up, during reboot, but it is Read-only file system.
Have you got any idea, where I can make changes, so after reboot, they will be kept and worked?
Thanks in advance !
#NAS_Dec_2019
| 11 18 * * * /path/hddreport.sh && /bin/cat /path/`date +\%Y-\%m-\%d`-hdd.txt | /usr/sbin/msmtp -a mailjet my@email |
Thanks in advance !
#NAS_Dec_2019
Best Answers
The NAS is embedded linux system, which has it's own rules. The rootfilesystem is basically an achive embedded in the kernel, which is extracted to a ramdrive. So yes, every change is lost after reboot.There are several ways to get around. The most easy way is to install Tweaks, which gives you a way to add cron entries, and RandomTools, which gives you a way to run custom scripts./i-data/sysvol/.PKG/RandomTools/etc/custom_startscripts/ behaves more or less like a 'normal' /etc/init.d/To install these packages first install MetaRepository.0
I put with wget http://http//zyxel.diskstation.eu/Users/Mijzelf/zypkg-repo/web_prefix
into /i-data/0...../admin
Then login using web gui, select apps - all apps - refresh button twice, but Metarepo
doesn't show for install, only this message:Download List Success
Can I put manually this file somewhere?
http://zyxel.diskstation.eu/Users/Mijzelf/zypkg-repo/NAS326/zypkg/5.21/MetaRepository_20181001_arm_015.zpkg
and repo be loaded from there?
So.. can you help me somehow to install it?
Thanks in advance !0 -
Any idea where I should put these line for example?
That's a profile command. You have (at least) 2 options. If you login as admin or root and have installed Tweaks you can give the user a persistent homedir with the 'Change Homedir' tool, and put a .profile there, or, when you installed RandomTools you can put a file in /i-data/sysvol/.PKG/RandomTools/etc/profile.d/, as you can read in the end of /etc/profile
You have to put the web_prefix file in \\<NAS>\admin\zy-pkgs\, or /i-data/../admin/zy-pkgs/
For zyxel 326 it says:
NAS326
(Firmware 5.10+ only) On this NAS there is no subdirectory zy-pkgs in \\<NAS>\admin\. Just add it.
I notice that should be in "zy-pkgs" folder - thanks !
I put this files here: /i-data/040781d8/admin/zy-pkgsZYPKGSbut still can't see in apps or "Tweaks"
ZYPKG_INFO.tgz
control.tar.gz data.tar.gz (extracted)
web_prefix
Also in MetaRepository trying to add this line
/i-data/sysvol/admin/zy-pkgs/ local
So.. when metarepo is installed, other apps are stop working like "zcloud" and "transmission" or I can remove zy-pkg folder it is only for install?
/i-data/sysvol/.PKG/MetaRepository/etc/init.d
this is folder that I should use?0 -
I put this files here:It doesn't hurt, but the only file needed is web_prefix. (Which, btw, is overwritten by MetaRepository). The rest of the files is ignored. MetaRepositorty creates a subdirectory here which contains it's own database.Also in MetaRepository trying to add this line
/i-data/sysvol/admin/zy-pkgs/ localSo you have it installed? In that case you only need to refresh the package list. If that doesn't show up more packages, there should be a logfile in \\<NAS>\admin\zy-pkgs\MetaRepository\, showing it's attempts to merge the repo's.Unless you have overwritten web_prefix after MetaRepository installed, in that case disable and enable MetaRepository to get the right web_prefix again.So.. when metarepo is installed, other apps are stop working like "zcloud" and "transmission" or I can remove zy-pkg folder it is only for install?Nothing stops by default. MetaRepository is just a way to merge the ZyXEL repo with one or more other repos. So you get more packages, not other.And no, you can't remove the zy-pkgs folder. The web_prefix file is a detour for the firmware's package system, which is initially used to get MetaRepository installed, but the MR uses it to point to itself.
Somehow with enable/disable it works. Now I can see both packages - zyxel and 3rd party.
Crontab is working.
alias ll="ls -al"
Using "change home dir" tool worked. Second method was not successful.
Thank you very much for the support !0
- 441 Beta Program
- 210 Nebula Ideas
- 538 USG FLEX H Series
- 340 Security Ideas
- 51 Wireless Ideas
- 295 Service & License
- 464 News and Release
