NAS320 Update drives from 1Tb to 2TB in Raid 1 configuration
metcas
I want to upgrade my Storage in a Raid 1 configuration. Is this the correct procedure
1. Remove 1 drive
2. Insert new 2Tb drive
3. Select Repair option, I assume that this will now be visible in the Volume / Actions column
4. Once repair completed repeat steps 1 - 3 with other drive
How then do I use the full 2Tb ?
Steve
#NAS_Dec_2019
1. Remove 1 drive
Steve
#NAS_Dec_2019
Actually the manual is pretty good! and gives the exact procedure which is as I had thought and then there should be an expand icon to incrase the size of the final raid. section 7.20
- 164 Beta Program
- 1.7K Nebula
- 86 Nebula Ideas
- 4.7K Security
- 236 Security Ideas
- 1.1K Switch
- 50 Switch Ideas
- 908 WirelessLAN
- 27 WLAN Ideas
- 5.3K Consumer Product
- 172 Service & License
- 294 News and Release
- 65 Security Advisories
- 14 Education Center
- 911 FAQ
- 399 Nebula FAQ
- 249 Security FAQ
- 90 Switch FAQ
- 100 WirelessLAN FAQ
- 18 Consumer Product FAQ
- 55 Service & License FAQ
- 68 About Community
- 51 Security Highlight
FAQ
