I have a VMG4381 modem with 500Mbps service.Only able to get approx 90Mbps.
dgsand
Are there settings on the modem I need to change?
#SP_Dec_2019
#SP_Dec_2019
I would suggest you to check with ISP firstlly to see if your modem is getting 500Mbps on WAN side. Also, if you are testing speed, make sure you do not have other traffic transferring data (such as bittorrent) at the time you are running speed test.
- 164 Beta Program
- 1.7K Nebula
- 86 Nebula Ideas
- 4.7K Security
- 236 Security Ideas
- 1.1K Switch
- 50 Switch Ideas
- 907 WirelessLAN
- 27 WLAN Ideas
- 5.3K Consumer Product
- 172 Service & License
- 294 News and Release
- 65 Security Advisories
- 14 Education Center
- 911 FAQ
- 399 Nebula FAQ
- 249 Security FAQ
- 90 Switch FAQ
- 100 WirelessLAN FAQ
- 18 Consumer Product FAQ
- 55 Service & License FAQ
- 68 About Community
- 51 Security Highlight
FAQ
