problem with backup sync zyxel from nas542 to nas 326
taceto32
Hi i have upgraded nas to 542 from 326 and i have done backup with service zyxelsync from 326 to 542 without problems.Now i use 542 as primary nas and want to sync it with 326 but i have problem becouse 542 return an error starting client server protocol, and i can use only rsync that work but give me void destination even if process says ok.
#NAS_Dec_2019
#NAS_Dec_2019
my idea is to use 326 as backup with zyxel sync and 542 as primary nas.0
i have problem becouse 542 return an error starting client server protocol.
What kind of error? Can you explain more information? Has any screenshot?
Do you want to backup NAS542 to NAS326? Which Type of Backup Planner you used?
I just test to backup files from NAS326 to NAS540 via rsync and it worked properly.
If you still have the problem, maybe you can share the setting for checking.0 -
hi, i have only message in backup planner and in a registry, i use zyxel sync utility and it gives me error, if i use rsync it works but i have blank target even if space is used...how can i view data in target of rsync?i have read that rsync and zyxel sync are the same but zyxel sync make destination same as origin, rsync gives me blank target...0
i have created same folders and users and permissions, and have rebooted 326 and 542 but nothing change, i have done exact inverse procedure from 326 to 542 with zyxel sync utility without problem0
Can you explain more clear about your problem?
Do you mean NAS326 -> NAS542 successfully, but NAS542 -> NAS326 failure?
Do you use Synchronization: Mirror or Rsync for backup?
After finished backup with Synchronization or Rsync, you should able to see files on destination folder which copy from source folder. And I checked NAS326 -> NAS540 or NAS540 -> NAS326, both worked properly.
Before you do backup job, do you able to access NAS326 (192.168.2.9)?
And is possible to share the log information on system?
You can use telnet/SSH log into your NAS device (source) and username is "root".
cd /i-data/sysvol/.system
Here are two log files.
cat zysync.log
cat zysyncd.log0 -
Yes i mean NAS326 -> NAS542 successfully, but NAS542 -> NAS326 failure
i use mirror and gives me error, Rsync works but i see no files in destination even if space is allocated and used.I can access in 326 and 542.
I use custom https port and http and i cannot log in by SSH.Can you give me default port?port 22 is not accessible by user root..and whic password i have to use?
i leave my configuration for 2 nasNasBackup 326http port 8900
https port 449user:adminpass:[email protected]!NasSmartercom 542http port 8700
https 447user:adminpass:[email protected]!0 -
SSH port is 22.
Can you also share the screenshots of the setting details about Backup Planner?
And source and destination folder information.0 -
here is log extracted from zysync.log
2019/12/11 10:33:25 [1902] @ERROR: auth failed on module Volume1@ERROR: auth failed on module Volume12019/12/11 10:33:25 [1902] rsync error: error starting client-server protocol (code 5) at main.c(1561) [sender=3.0.0]rsync error: error starting client-server protocol (code 5) at main.c(1561) [sender=3.0.0]2019/12/11 10:34:23 [2173] @ERROR: auth failed on module Volume1@ERROR: auth failed on module Volume12019/12/11 10:34:23 [2173] rsync error: error starting client-server protocol (code 5) at main.c(1561) [sender=3.0.0]rsync error: error starting client-server protocol (code 5) at main.c(1561) [sender=3.0.0]2019/12/11 10:35:53 [2549] @ERROR: auth failed on module Volume1@ERROR: auth failed on module Volume12019/12/11 10:35:53 [2549] rsync error: error starting client-server protocol (code 5) at main.c(1561) [sender=3.0.0]rsync error: error starting client-server protocol (code 5) at main.c(1561) [sender=3.0.0]2019/12/11 10:45:49 [4365] @ERROR: auth failed on module Volume1@ERROR: auth failed on module Volume12019/12/11 10:45:49 [4365] rsync error: error starting client-server protocol (code 5) at main.c(1561) [sender=3.0.0]rsync error: error starting client-server protocol (code 5) at main.c(1561) [sender=3.0.0]2019/12/11 10:47:58 [5510] building file list[DEBUG]: /i-data/f6255952/ is a directory.[DEBUG]: zysync -avHSO8 --exclude-from=/etc/zyxel/BackupPlanner/zysync/zysync_exclude_files --password-file=/tmp/rsync.pwd --bwlimit=0 /i-data/f6255952/ [email protected]::Volume1/ --log-file=/i-data/.system/zysync.log --progress --deletesending incremental file list
here is log from zysyncd.log2015/05/25 22:00:13 [start] zysync server(3172) exists, please stop it first.2015/05/25 22:02:42 [2975] zysync server v2.00 starting, listening on port 873.2015/05/25 22:05:03 [2975] rsync error: received SIGINT, SIGTERM, or SIGHUP (code 20) at rsync.c(506) [receiver=3.0.0]2015/05/25 22:07:50 [3012] zysync server v2.00 starting, listening on port 873.2015/05/26 00:29:29 [3386] zysync server v2.00 starting, listening on port 873.2015/05/26 00:32:17 [3386] rsync error: received SIGINT, SIGTERM, or SIGHUP (code 20) at rsync.c(506) [receiver=3.0.0]2015/05/26 00:35:29 [3361] zysync server v2.00 starting, listening on port 873.2019/11/18 14:26:55 [16792] generate zysync server config2019/11/18 14:26:56 [16792] name lookup failed for 192.168.1.254: Name or service not known2019/11/18 14:26:56 [16792] connect from UNKNOWN (192.168.1.254)2019/11/18 14:26:56 [16792] module-list nick request from UNKNOWN (192.168.1.254)2019/11/18 14:26:56 [16792] send_listing enter2019/11/18 14:26:56 [16792] Volume12019/11/18 14:26:56 [16792] send_listing exit2019/11/18 14:26:56 [16792] unknown module '' tried from UNKNOWN (192.168.1.254)2019/11/18 14:26:56 [16825] generate zysync server config2019/11/18 14:26:56 [16825] name lookup failed for 192.168.1.254: Name or service not known2019/11/18 14:26:56 [16825] connect from UNKNOWN (192.168.1.254)2019/11/18 14:26:56 [16825] remote standard rsync login successfully. (host: UNKNOWN, addr: 192.168.1.254, user: admin, secret: ****, pass: ****)2019/11/18 14:28:55 [17178] generate zysync server config2019/11/18 14:28:56 [17178] name lookup failed for 192.168.1.254: Name or service not known2019/11/18 14:28:56 [17178] connect from UNKNOWN (192.168.1.254)2019/11/18 14:28:56 [17178] rsync auth failed on module Volume1 from UNKNOWN (192.168.1.254): password mismatch -> try zysync2019/11/18 14:28:56 [17178] remote zysync login successfully. (host: UNKNOWN, addr: 192.168.1.254, user: admin, pass: ****)2019/11/18 20:05:50 [2293] generate zysync server config2019/11/18 20:05:53 [2293] name lookup failed for 192.168.1.254: Name or service not known2019/11/18 20:05:53 [2293] connect from UNKNOWN (192.168.1.254)2019/11/18 20:05:53 [2293] rsync auth failed on module Volume1 from UNKNOWN (192.168.1.254): password mismatch -> try zysync2019/11/18 20:05:53 [2293] remote zysync login successfully. (host: UNKNOWN, addr: 192.168.1.254, user: admin, pass: ****)2019/11/19 12:48:17 [3361] rsync error: received SIGINT, SIGTERM, or SIGHUP (code 20) at rsync.c(506) [receiver=3.0.0]2019/11/19 12:50:33 [3473] zysync server v2.00 starting, listening on port 873.2019/11/19 13:16:07 [18930] generate zysync server config2019/11/19 13:16:07 [18930] name lookup failed for 192.168.1.254: Name or service not known2019/11/19 13:16:07 [18930] connect from UNKNOWN (192.168.1.254)2019/11/19 13:16:07 [18930] rsync auth failed on module Volume1 from UNKNOWN (192.168.1.254): password mismatch -> try zysync2019/11/19 13:16:07 [18930] remote zysync login successfully. (host: UNKNOWN, addr: 192.168.1.254, user: admin, pass: ****)2019/11/19 13:43:26 [3374] generate zysync server config2019/11/19 13:43:26 [3374] name lookup failed for 192.168.1.254: Name or service not known2019/11/19 13:43:26 [3374] connect from UNKNOWN (192.168.1.254)2019/11/19 13:43:26 [3374] rsync auth failed on module Volume1 from UNKNOWN (192.168.1.254): password mismatch -> try zysync2019/11/19 13:43:27 [3374] remote zysync login successfully. (host: UNKNOWN, addr: 192.168.1.254, user: admin, pass: ****)2019/11/19 13:50:45 [6048] generate zysync server config2019/11/19 13:50:45 [6048] name lookup failed for 192.168.1.254: Name or service not known2019/11/19 13:50:45 [6048] connect from UNKNOWN (192.168.1.254)2019/11/19 13:50:45 [6048] rsync auth failed on module Volume1 from UNKNOWN (192.168.1.254): password mismatch -> try zysync2019/11/19 13:50:46 [6048] remote zysync login successfully. (host: UNKNOWN, addr: 192.168.1.254, user: admin, pass: ****)2019/11/19 14:05:44 [3473] rsync error: received SIGINT, SIGTERM, or SIGHUP (code 20) at rsync.c(506) [receiver=3.0.0]2019/11/19 14:23:52 [3359] zysync server v2.00 starting, listening on port 873.2019/12/11 10:43:02 [3359] rsync error: received SIGINT, SIGTERM, or SIGHUP (code 20) at rsync.c(506) [receiver=3.0.0]2019/12/11 10:44:52 [3374] zysync server v2.00 starting, listening on port 873.2019/12/19 10:49:00 [3374] rsync error: received SIGINT, SIGTERM, or SIGHUP (code 20) at rsync.c(506) [receiver=3.0.0]2019/12/19 10:50:53 [3291] zysync server v2.00 starting, listening on port 873.2019/12/19 10:57:50 [3300] zysync server v2.00 starting, listening on port 873.2019/12/19 23:45:52 [3305] zysync server v2.00 starting, listening on port 873.0 -
zysync.log
.2019/12/11 10:47:58 [5510] building file list
.[DEBUG]: /i-data/f6255952/ is a directory.
.sending incremental file list
It seems no start backup process.
I saw you backup whole NAS542 volume to NAS326. Has NAS326 enough space?
Can you try to simply only backup one folder for testing this problem?
And is possible to provide the screenshots about backup job setup/setting/steps to clarify it?
i tried backup only one folder witout success...nas326 has same hd as 542, i have created same folders and permissions but backup not start...screenshots of planner options is in previous post0
- 6.9K All Categories
- 2 Education Center
- 1.4K Nebula
- 34 Nebula Ideas
- 40 Nebula Status and Incidents
- 3.9K Security
- 203 Security Ideas
- 751 Switch
- 31 Switch Ideas
- 633 WirelessLAN
- 10 WLAN Ideas
- 4.6K Consumer Product
- 105 Service & License
- 223 News and Release
- 39 Security Advisories
- 522 FAQ
- 239 Nebula FAQ
- 121 Security FAQ
- 73 Switch FAQ
- 67 WirelessLAN FAQ
- 6 Consumer Product FAQ
- Documents
- 30 Nebula Monthly Express
- 44 About Community
- 32 Security Highlight
