Cannot connect Roborock S55 to LTE4506-M606
Adronalin
recently I use the LTE4506-M606. My Roborock S55 cannot connect to this network.
If i try to install the vacuumer it said the connection timed out
It can connet to my old LTE router and a Fritzbox DSL router.
I have the latest Firmware on the vacuumer and router.
All ports are open and firewall settings are default.
Maybe someone can help
Adronalin
#SP_Jan_2020
Hi Sir
You mean your Roborock S55 cannot connect to Wi-Fi right? May I ask if you set LTE4506 Wi-Fi connection no need password, will issue still happen? This action used to check if the problem occurred during authentication check progress. Thank you.0
- 588 USG FLEX H Series
- 476 News and Release
