Nas540 freezing at startup
Whaxnalle
Posts: 8 Freshman Member
When I tried to start my nas540 the lights for power light up but then it freeze. To shut it down I need to remove power cord. Only power led is lighting up. Not the led for disks. Feels like firmvare problem tried using a USB recovery but it does not start te recovery. Anyone have a suggestion to what to do?
#NAS_Jan_2020
#NAS_Jan_2020
Have you tried it without disks?
Yes I tried to start without disk same problem.0
OK, that largely excludes a faulty power supply. My next guess would be a corrupt flash. That might be recoverable, but needs some low-level actions. You'll have to hook up a serial cable (3.3V TTL. An RS232 'PC cable' won't do). Info on the serial port here.
What actually has to be done is not yet clear. You first have to catch a serial bootlog, and see where it ends.About the access to the serial port I can tell that you have to remove the front and back, and then split the remaining cover on it's seam. I used some (long) table knives to detach the hooks which connect the two halves.When you have isolated the motherboard, you have also removed the heatsink of the processor. I can't remember that that gave any problems, but someone else reported the processor became pretty hot. So keep an eye on that.0
Okay, I will try that. I don't have the cable I need will get one and try. I report back when I have done this. ?0
- 385 Beta Program
- 2.1K Nebula
- 116 Nebula Ideas
- 80 Nebula Status and Incidents
- 5.1K Security
- 74 USG FLEX H Series
- 247 Security Ideas
- 1.3K Switch
- 70 Switch Ideas
- 907 WirelessLAN
- 34 WLAN Ideas
- 5.9K Consumer Product
- 210 Service & License
- 335 News and Release
- 71 Security Advisories
- 21 Education Center
- 1.9K FAQ
- 886 Nebula FAQ
- 415 Security FAQ
- 228 Switch FAQ
- 199 WirelessLAN FAQ
- 46 Consumer Product FAQ
- 137 Service & License FAQ
- 73 About Community
- 63 Security Highlight
