CPU usare 100% in Nsa325v2
Tomcor75
Tomcor75 Posts: 2 image  Freshman Member
edited January 2020 in Personal Cloud Storage
Sorry for my trouble english. I’ve a NSA325-v2 whit the last firmware. The cpu is always at 100% (Python at 100%). The cpu goes at low rate only if i disable the multimedia server. Is there a way to enable the multimedia server without having the cpu at 100%? I real that have ti disable the thumbnail creation. How can i disable it with this firmware? Thank you
#NAS_Jan_2020
  • Mijzelf
    Mijzelf Posts: 3,042 image  Guru Member
    I wrote a package 'Tweaks' which can (among other goodies) disable some firmware scripts/daemons.
    To install it you first have to install MetaRepository, for which you can find instructions here. Scroll to the end.
