NSA325 v2 doesn't work
The NSA has the power on button blue light but any of the other lights are off but If I open it, I can see the led corresponding with the second disk with a little green light. The fan is running. It was working normally and I found in this state. The blue light is ON, It sounds like it is trying to start the hard disks but after a few seconds, its power off and then power on again.
I had this problem other times but the NSA worked again after cut the power and restart in a few minutes.
I tried to press the reset button. It doesn't work.
I tried to remove the disks and start again. Same effect. No changes.
I tried to press the power-on button for a few seconds. No changes.
I read the troubleshooting manual sections but I can't find this scenario.
Any solution?
Thanks!
#NAS_May_2019
Is that with out without disks? If the box starts without disks, it's probably a broken powersupply. If it also doesn't start without disks, I'm afraid it's dead.
Same Problem, what was your solution?
What about the data on the nas?
- 220 Nebula Ideas
- 607 USG FLEX H Series
- 482 News and Release
