FFMPEG not working on NSA325v2. Did I install it wrongly?
AleXSR700
AleXSR700 Posts: 41 image  Freshman Member
edited February 2020 in Personal Cloud Storage
Hi everyone,
I wanted to install ffmpeg, but it seems I am doing something wrong.
I ran slacker -Ui and then installed ffmpeg.
But I cannot run ffmpeg in shell. It is not being found.
I have ffp and entware-ng installed next to each other, if that matters.
<code>
sudo find . -print | grep -i 'ffmpeg*' ./ram_bin/usr/local/dmsf/binary/cgi-bin/ffmpeg-video-thumb.desc ./usr/local/dmsf/binary/cgi-bin/ffmpeg-video-thumb.desc ./usr/local/zy-pkgs/ffproot/ffp/funpkg/removed/ffmpeg-0.8.7-arm-1,reinstalled,202002 07_034542 ./usr/local/zy-pkgs/ffproot/ffp/funpkg/installed/ffmpeg-0.8.7-arm-1 ./usr/local/zy-pkgs/ffproot/ffp/funpkg/cache/s/ffmpeg-0.8.7-arm-1.txz ./e-data/e9902f35-4024-4b41-9626-08c2131c7087/jd2/cfg/org.jdownloader.controlling.ff mpeg.FFmpegSetup.dash2m4acommand.json ./e-data/e9902f35-4024-4b41-9626-08c2131c7087/jd2/cfg/org.jdownloader.controlling.ff mpeg.FFmpegSetup.dash2oggaudiocommand.json ./e-data/e9902f35-4024-4b41-9626-08c2131c7087/jd2/cfg/org.jdownloader.controlling.ff mpeg.FFmpegSetup.dash2opusaudiocommand.json ./e-data/e9902f35-4024-4b41-9626-08c2131c7087/jd2/cfg/org.jdownloader.controlling.ff mpeg.FFmpegSetup.muxtomp4command.json ./e-data/e9902f35-4024-4b41-9626-08c2131c7087/jd2/cfg/org.jdownloader.controlling.ff mpeg.FFmpegSetup.demux2m4acommand.json ./e-data/e9902f35-4024-4b41-9626-08c2131c7087/jd2/cfg/org.jdownloader.controlling.ff mpeg.FFmpegSetup.demuxgenericcommand.json ./e-data/e9902f35-4024-4b41-9626-08c2131c7087/jd2/cfg/org.jdownloader.controlling.ff mpeg.FFmpegSetup.muxtowebmcommand.json ./e-data/e9902f35-4024-4b41-9626-08c2131c7087/jd2/cfg/org.jdownloader.controlling.ff mpeg.FFmpegSetup.demux2mp3command.json ./e-data/e9902f35-4024-4b41-9626-08c2131c7087/jd2/cfg/org.jdownloader.controlling.ff mpeg.FFmpegSetup.demuxandconvert2ogg.json ./e-data/e9902f35-4024-4b41-9626-08c2131c7087/jd2/cfg/org.jdownloader.controlling.ff mpeg.FFmpegSetup.extensiontoformatmap.json ./e-data/e9902f35-4024-4b41-9626-08c2131c7087/jd2/cfg/org.jdownloader.controlling.ff mpeg.FFmpegSetup.dash2aaccommand.json ./e-data/e9902f35-4024-4b41-9626-08c2131c7087/jd2/cfg/org.jdownloader.controlling.ff mpeg.FFmpegSetup.demux2aaccommand.json ./e-data/e9902f35-4024-4b41-9626-08c2131c7087/jd2/cfg/org.jdownloader.controlling.ff mpeg.FFmpegSetup.muxtomkvcommand.json ./e-data/e9902f35-4024-4b41-9626-08c2131c7087/jd2/themes/standard/org/jdownloader/im ages/logo/ffmpeg.png.license ./e-data/e9902f35-4024-4b41-9626-08c2131c7087/jd2/themes/standard/org/jdownloader/im ages/logo/ffmpeg.png ./e-data/e9902f35-4024-4b41-9626-08c2131c7087/jd2/logs/1580741728735_Mon, Feb 3, 202 0 14.55 +0000/org.jdownloader.controlling.ffmpeg.FFmpeg.log.0.lck ./e-data/e9902f35-4024-4b41-9626-08c2131c7087/jd2/logs/1580741728735_Mon, Feb 3, 202 0 14.55 +0000/org.jdownloader.controlling.ffmpeg.FFmpeg.log.0 ./i-data/c7d796b4/.system/zy-pkgs/ffproot/ffp/funpkg/removed/ffmpeg-0.8.7-arm-1,rein stalled,20200207_034542 ./i-data/c7d796b4/.system/zy-pkgs/ffproot/ffp/funpkg/installed/ffmpeg-0.8.7-arm-1 ./i-data/c7d796b4/.system/zy-pkgs/ffproot/ffp/funpkg/cache/s/ffmpeg-0.8.7-arm-1.txz root@NSA325-v2-101:/#
</code>
Any ideas anyone?
Thank you for your help :)
#NAS_Feb_2020
  • AleXSR700
    P.S.: Does anybody know how you can tell slacker to ignore missing checksums.md5? It's preventing me from downloading from e.g. barmelej2.
    It also happens with others and then simply aborts:
    Updating package lists... fetch: rsync -q 'rsync://ffp.inreto.de/ffp/0.7/arm/packages/CHECKSUMS.md5' '/ffp/funpkg/cache/s' fetch: (cd '/ffp/funpkg/cache/mz'; wget -Nnv 'http://downloads.zyxel.nas-central.org/Users/Mijzelf/FFP-Stick/packages/0.7/arm/CHECKSUMS.md5') FATAL: mz: No CHECKSUMS.md5 Thanks for using UW Site Loader! root@NSA325-v2-101:/ffp/bin#
  • Mijzelf
    Mijzelf Posts: 3,038 image  Guru Member
    I suppose you installed ffmpeg-0.8.7-arm-1.txz, which contains only libraries, and no executable. You could install ffmpeg-1.1.1-arm-2.txz instead, which also contains a binary.
    About the checksums.md5, you have to edit your /ffp/etc/funpkg/sites, and remove the dead links.
  • AleXSR700
    So your own link is dead? I get the same error from your server.
    Also, I cannot select to install a different ffmpeg because there is none on any of the working servers :(
  • Mijzelf
  • AleXSR700
    Okay, got it running now, thank you :)
    However, the ffmpeg in your own repository does not include the libshine.so and therefor does not work. I had to install the br2 version.
    For some reason jDownloader still claims that FFMPEG is missing :(
    <div>ffmpeg version 0.10.2 Copyright (c) 2000-2012 the FFmpeg developers</div><div>&nbsp; built on Apr&nbsp; 2 2012 13:27:15 with gcc 4.5.4 20111110 (prerelease)</div><div>&nbsp; configuration: --prefix=/ffp --disable-static --enable-shared --enable-gpl --enable-nonfree --enable-small --disable-encoder=aac --disable-decoder=aac --disable-armv6 --disable-armv6t2 --disable-armvfp</div><div>&nbsp; libavutil&nbsp; &nbsp; &nbsp; 51. 35.100 / 51. 35.100</div><div>&nbsp; libavcodec&nbsp; &nbsp; &nbsp;53. 61.100 / 53. 61.100</div><div>&nbsp; libavformat&nbsp; &nbsp; 53. 32.100 / 53. 32.100</div><div>&nbsp; libavdevice&nbsp; &nbsp; 53.&nbsp; 4.100 / 53.&nbsp; 4.100</div><div>&nbsp; libavfilter&nbsp; &nbsp; &nbsp;2. 61.100 /&nbsp; 2. 61.100</div><div>&nbsp; libswscale&nbsp; &nbsp; &nbsp; 2.&nbsp; 1.100 /&nbsp; 2.&nbsp; 1.100</div><div>&nbsp; libswresample&nbsp; &nbsp;0.&nbsp; 6.100 /&nbsp; 0.&nbsp; 6.100</div><div>&nbsp; libpostproc&nbsp; &nbsp; 52.&nbsp; 0.100 / 52.&nbsp; 0.100</div><div>Hyper fast Audio and Video encoder</div><div>usage: ffmpeg [options] [[infile options] -i infile]... {[outfile options] outfile}...</div><div><br></div><div>Use -h to get full help or, even better, run 'man ffmpeg'</div><div>admin@NSA325-v2-101:~$</div>
  • AleXSR700
    Okay, got ffmpeg up and running with your version. Had to install a few more things
    ffmpeg-1.1.1-arm-2, x264-20130313-arm-1, twolame-0.3.13-arm-1, shine-20130313-arm-1, rtmpdump-2.3-arm-1, opus-1.0.2-arm-1, fdk_aac-20130313-arm-1,
    libass-0.10.1-arm-1, freetype-2.4.11-arm-1, fribidi-0.19.5-arm-1, fontconfig-2.10.91-arm-1
    But jDownloader still won't work. Tried setting the path to '/ffp/bin/' but jDownloader just tells me that the new value could not be set.
  • Mijzelf
    Don't know if my version is better than br2's. It's long ago that I created the package on request.
    And sorry, I have no idea how jDownloader expects to find ffmpeg.
