NSA325-v2 - SkyHawk support?
Lefty
It seems that my NSA325 doesn't recognize 6TB Seagate SkyHawk drive. Could that be the case?
Rather - is there high risk that specific drives might not work if are not on supported HDD list? Or normally most of HDD should work plug-and-play right away?
#NAS_Feb_2020
#NAS_Feb_2020
Are you sure that disk is alive? Sata is sata. Any disk which meets the sata specs should work, unless it can't spin up due to power constraints. I never had a random disk in a random NAS rejected.
Yea, I did health checks on windows system.
Thanks for the answer though, I'll play around a bit, with assumption that it should work.0
- 164 Beta Program
- 1.7K Nebula
- 86 Nebula Ideas
- 4.7K Security
- 236 Security Ideas
- 1.1K Switch
- 50 Switch Ideas
- 908 WirelessLAN
- 27 WLAN Ideas
- 5.3K Consumer Product
- 172 Service & License
- 294 News and Release
- 65 Security Advisories
- 14 Education Center
- 911 FAQ
- 399 Nebula FAQ
- 249 Security FAQ
- 90 Switch FAQ
- 100 WirelessLAN FAQ
- 18 Consumer Product FAQ
- 55 Service & License FAQ
- 68 About Community
- 51 Security Highlight
FAQ
