amg1302-t10c as a wireless adapter
cfcc2020
I wanted to use the amg1302-t10c router as a wireless adapter (i.e. PC to this
router via ethernet cable, then this router to main router via wireless
connection) to boost internet speed of the PC. I searched everywhere and
could not find anything except to flash dd wrt into it, but this model
is not supported. I found the manual for the amg1302-t11c, but nothing
there either. Any ideas on how I can achieve this seemly simple task?
Tried setting it up as a bridge, but that didn't work either. Any help will
be much appreciated. Thank you.
Thank you. Is there any way of confirming this? Thanks again
Hi @cfcc2020AMG1302-T10C is designed to be used as a router or a gateway.
It doesn't support the feature to be a wireless repeater.
We suggest to connect the WAN port of AMG1302-T10C to your main router with an Ethernet cable according to your description.0
- 164 Beta Program
- 1.7K Nebula
- 86 Nebula Ideas
- 4.7K Security
- 236 Security Ideas
- 1.1K Switch
- 50 Switch Ideas
- 907 WirelessLAN
- 27 WLAN Ideas
- 5.3K Consumer Product
- 172 Service & License
- 294 News and Release
- 65 Security Advisories
- 14 Education Center
- 911 FAQ
- 399 Nebula FAQ
- 249 Security FAQ
- 90 Switch FAQ
- 100 WirelessLAN FAQ
- 18 Consumer Product FAQ
- 55 Service & License FAQ
- 68 About Community
- 51 Security Highlight
FAQ
