EMG3425 Port Fowarding Help
NClack
I need some help with port forwarding on my EMG3425...
All of the guides I have come across show a NAT/Port Fowarding page that looks nothing like mine does, mainly that the field "Translation Port" is not present anywhere except my router.
I have a static IP setup with my ISP, and that is active, and I am trying to setup a VPN using port 1194.
The VPN server has been set up and has been assigned a static IP of 192.168.1.4 in my network.
When I attempt to setup my forwarding rule, using 1194 as both the port and translation port, I can never see it open from the outside.
What am I missing here?
#SP_Mar_2020
#SP_Mar_2020
Hi NClack,
May i know your Firmware Version ?
Based on my experience, the port forwarding page should here " Configuration-->Network > NAT > Port Forwarding"
Where can I find my current firmware version?
Looking through the entire menu I cannot find an entry for current firmware version, only the option to update firmware.
Port Forwarding IS Config > Network > NAT > Port Forwarding
My issue is that no matter what I set, I cannot open a port to the outside
I found it
V1.00(AAYJ.13)C0_20180921
Hi NClack,
I also have one HTTP server on port 1194, you can refer my setting below
Hope this could help you.0
- 164 Beta Program
- 1.7K Nebula
- 86 Nebula Ideas
- 4.7K Security
- 236 Security Ideas
- 1.1K Switch
- 50 Switch Ideas
- 907 WirelessLAN
- 27 WLAN Ideas
- 5.3K Consumer Product
- 172 Service & License
- 294 News and Release
- 65 Security Advisories
- 14 Education Center
- 911 FAQ
- 399 Nebula FAQ
- 249 Security FAQ
- 90 Switch FAQ
- 100 WirelessLAN FAQ
- 18 Consumer Product FAQ
- 55 Service & License FAQ
- 68 About Community
- 51 Security Highlight
FAQ
