L2tp client configuration sbg-3300
Art
Art Posts: 1 image  Freshman Member
Fourth Anniversary
edited March 2020 in Smart Home Product
Hi , using my sbg-3300 zyxel router i am trying to connect to client vpn server using L2TP configuration , but i am unable to connect. Can anyone help pls ?.
thanks
#SP_Mar_2020
  • bbb
    bbb Posts: 35 image  Freshman Member
    Sixth Anniversary
    Hi Art,
    Few questions:
    1. Which firmware version is your SBG3300 using?
    2. I would like to confirm the type of VPN you would like to use, is it L2TP VPN or L2TP over IPsec VPN?
    3. Is the VPN server also running on an SBG3300?
    4. Could you please take a screenshot of the L2TP VPN page (VPN > L2TP VPN) so that I can check your settings?
    Thank you.
    Bob
