PLEX on NAS542
135
  • Mijzelf
    Mijzelf Posts: 2,395
    250 Answers 1000 Comments Friend Collector Fifth Anniversary
    You can find your shares in /i-data/<some-long-hex-name>/
  • zorro68
    zorro68 Posts: 3  Freshman Member
    Hi all,
    I have a problem with the last step. When I install plex server in the nas, I don't have any problem, but plex ask me for user (I have a user in plex some years ago), I select this user but I cannot select my nas, it doesn't appear.... What am I doing bad?
    Thanks in advance
  • NAGROBE
    NAGROBE Posts: 11
    Second Anniversary
    Hi Friend,
    I have the same problem as you.
    My divice is NAS542.
    Was your divice (NAS542) on based setting before the installation of web_prefix file?
    Was your admin folder empty?
    My problem is, I saved the web_prefix to the right place (\\<NAS\admin\) but in spite of this after refreshing the App Center there is no MetaRepository aplication avaiable.
    I have done everything as described.
    I would be grateful for any idea or suggestion.
    Thank you in advance and take care!
  • Emerald Dragon
    Emerald Dragon Posts: 118
    First Anniversary
    edited April 2020
    @NAGROBE, you have to create the folder "zy-pkgs" and upload the web_prefix file there in order for it to work.
    \\NAS\Admin\zy-pkgs\
  • NAGROBE
    NAGROBE Posts: 11
    Second Anniversary
    @Emerald Dragon
    unfortunately it does not work.
  • Emerald Dragon
    First Anniversary
    @NAGROBE, How did you downloaded the web_prefix file? Did you right-click and download it from the site?
  • NAGROBE
    NAGROBE Posts: 11
    Second Anniversary
    @Emerald Dragon Yes, right-click and 'save as' to the right folder and there is no extension, only simple file.
  • Mijzelf
    @NAGROBE Well, at least the files is recognized and handled. Else you wouldn't get that fail message. According to your first screenshot you opened it in notepad. I hope you didn't save it?
    Can you ping zyxel.diskstation.eu from the NAS?
  • NAGROBE
    NAGROBE Posts: 11
    Second Anniversary
    @Mijzelf
    Hello, thank you for your feedback! Unfortunately I don't have opportunity to check it today. I will do it tomorrow and let you know the result.
  • NAGROBE
    NAGROBE Posts: 11
    Second Anniversary
    @Mijzelf
    How do I start a command prompt from a NAS?
    How to "PING" a NAS?
