Router NBG-418N v2 ntp, syslog, telnet
Luca
Luca Posts: 1
edited April 2020 in Home Router
Hello, I use the NBG in AP mode.
I have had an intrusion problem in my LAN. I founded a brute force attack logged by the device. So i'm trying to secure a little. First I noticed time is wrong... time resets after reboot... it is not possible to set a NTP server, so i cannot try to match time in the (other) firewall syslog. Also it is not possible to send logs to an external syslog server.
I noticed the router has telnet port open, so I tried to connect via telnet. I login as admin, but don't know exactly what I can do. Is it possible to set NTP server and syslog server via CLI? Is there documentation about CLI command?
Hope to be clear, thanks in advance, L
#Home_Router_Apr_2020
  • Hill
    Hill Posts: 156
    To my knowledge, it's impossible due to design limitation.
    NBG418Nv2 in AP mode cannot set gateway information to synchronize time zone with the NTP server. So, you need to synchronize time manually after reboot.
