[NEBULA] Is it possible to create Virtual WAN port
Hi Larry_FIN
NSG dose not support the virtual interface for both WAN/LAN at present. Since we already received the same feature request for discussion, we will update to you once the roadmap of the feature is confirmed. Please stay tuned for the notification.
Zyxel Nebula Support
6
Hi Larry_FIN
6 -
Does this mean we can't create a virtual lan adapter as a gateway for dmz?0
@FrankIversen
NSG does not support the establishment of virtual lan adapter for dmz at present. We are still under evaluation of the virtual interface and will get back to you as long as the feature is confirmed in our future roadmap.Zyxel Nebula Support
we have 2 public wan ips. we want the it-department to run internally on LAN2 and use 1 specific wan ip for outbound traffic (due to some dashboards around which only accepts communication from our public ip).
the other
@FrankIversen
This application requires Nebula CC to support both Virtual interfaces and Policy Routing.
Policy Routes will be introduced to Nebula on Phase 4, scheduled to release on the 2nd half of 2018.
Unfortunately, there has been no plans yet to support virtual interfaces on the NSG. I will create this request under our Ideas section. With enough likes, perhaps we can add this in to our road map faster!
Regards,
Barney0 -
Has this now been implemented?
If so, any help documents for it?
Many thanks
Richard0 -
Hello @CommsCo
About policy route, yes it has been implemented on September
, for the WAN virtual interface it's in our roadmap already but we're still working on this I can't give you a precise schedule in this moment, please stay tuned.
/Chris0 -
Hello @Nebula_Chris
has the Virtual IP been implemented? I am facing the same situation as Larry_FIN. I need to use multiple public IPs on a single WAN port of a NSG200
Many thanks
Hi @Azzie
Welcome to the Nebula community!!☺️
May I know if you're planing to use it on virtual server? If it is the case then please refer to the below screenshot, you can still put IP in Public IP column, which can get same result as virtual interface.
Hello @Nebula_Chris ,
I've tested it and it seems to work, many thanks for the info!
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 482 News and Release
