Multy x app stays disconnected
Same problem here. Iphone X, iOS 12.4, I’ve tried to setup newly bought Multy kit 3. First Multy created a network, but in the final “picture” showed Bluetooth settings error and offers two options: try again to connect to Internet via Bluetooth or to reset Multy. I tried both options, tried to swap two Multy-s and received same error! The Multy App shows clean place with no nodes in it, but I do have wi-fi working! I tried to view the internet connection through Diagnostics and it showed “unknown” node. But after I closed and re-opened the app it looks like I just had installed it - it offers a setup, and shows no nodes at all. I have no idea what to do
Do you mean you cannot install Multy node successfully?
Can you share the screenshot about the failure message?
Please go to iPhone X's Settings > Bluetooth, then disable and re-enable Bluetooth to try again.
Do you know the LED status during the problem happened? And what is your network topology?0 -
I have the same problem. Installing the first Multy X, creating WiFi, worked fine. But if I want (and I need it) to configure the Multy X or to add a new Multy X, I cant do it, because the app shows "disconnected" even if its connectsed to the WiFi. very strange, need help asap, otherwise I cant use my Multy X.0
same error to me!!!0
my phone is a iPhone X with iOS 140
- 164 Beta Program
- 1.7K Nebula
- 86 Nebula Ideas
- 4.7K Security
- 236 Security Ideas
- 1.1K Switch
- 50 Switch Ideas
- 908 WirelessLAN
- 27 WLAN Ideas
- 5.3K Consumer Product
- 172 Service & License
- 294 News and Release
- 65 Security Advisories
- 14 Education Center
- 911 FAQ
- 399 Nebula FAQ
- 249 Security FAQ
- 90 Switch FAQ
- 100 WirelessLAN FAQ
- 18 Consumer Product FAQ
- 55 Service & License FAQ
- 68 About Community
- 51 Security Highlight
FAQ
