NAS540 only connects at 100Mb/s
ombre33
I have tried different cables, switches, routers. NAS540 will always only connect at 100Mb/s. This is what ethtool has to say:
Supported link modes: 10baseT/Half 10baseT/Full
100baseT/Half 100baseT/Full
1000baseT/Half 1000baseT/Full
Supported pause frame use: Symmetric Receive-only
Supports auto-negotiation: Yes
Advertised link modes: 10baseT/Half 10baseT/Full
Advertised pause frame use: Symmetric Receive-only
Advertised auto-negotiation: Yes
Speed: 100Mb/s
Duplex: Full
Port: MII
PHYAD: 4
Transceiver: external
Auto-negotiation: on
Current message level: 0x00000036 (54)
probe link ifdown ifup
Link detected: yes
Trying to set the speed manually to 1000Mb/s seems to send the NIC into a state where it keeps toggling on and off every few seconds and only a reboot will make the NAS reachable again.
Not really sure where to go from here and any help would be much appreciated.
Thanks.
It seems the poor cable quality cannot meet 1G speed but you still manually fixed it.
Have you tried cross-test (cable and port) to rule out the cause?
Yes I have. But just for good measure, I tried again with a cable and port of a device that I know gets 1000Mb/s. Even there, NAS540 still only gets 100Mb/s.
How about another port? are both two ports on your NAS not able to get 1G speed?
And try fix at 1G speed on both side of link? NAS540 <---> Switch, Router
Maybe it's HW issue...0 -
Trying Port 2 on the NAS was a good idea, and indeed something I hadn't tried yet. But it will still only connect at 100Mb/s.Switch won't let me manually choose a speed faster than 100Mb/s.HW issue? Kinda doubt that both ports on the NAS are now faulty. And upon start-up of the NAS I can see in the web IF of the switch that the NAS tries to connect to 1000Mb/s, then disconnects, then reconnects at 100Mb/s.0
Change another cable for another try? sometimes it just can't fit on specific devices
Alright, I feel kind of stupid for having to admit this, but I guess it serves me right for not checking the simplest solution first: A good blast of compressed air to Port 1 remedied that problem.Thanks so much for your help, still!0
Really? compressed air? mine has been like this since i got it (maxing out at about 10-12MB/s)0
I had a similar issue with a NAS520, suddenly it would only connect with 100 Mbps. I tried different cables but that didn't work. I was able to fix it using the info found in the thread below, read it first. Disable link aggregation if you use that.Have you read this: https://homeforum.zyxel.com/discussion/721/nas-326-gigabit-connection-failureAfter this command, reboot the device without any connected network cables. I'm not sure if this is really necessary but in my situatioin is wasn't solved the first time.
ethtool -s egiga0 speed 1000 duplex full autoneg on
When the device is fully booted up (after 4-5 minutes or so) power it down by pressing the power button. Then connect 1 network cable and reboot the device and checkControl Panel > TCP/IP > Network Interface
Status should be: 1000 Mbps, full-duplex
- 439 Beta Program
- 2.8K Nebula
- 200 Nebula Ideas
- 6.3K Security
- 497 USG FLEX H Series
- 323 Security Ideas
- 83 Switch Ideas
- 49 Wireless Ideas
- 286 Service & License
- 457 News and Release
- 89 Security Advisories
- 4.3K FAQ
- 95 Security Highlight
