Multy X - Two satellite nodes connection via ethernet backhaul
phoner123
Is it possible to connect two satellite nodes via ethernet backhaul? The main Multy is in the ground floor and that connects to the top floor study Multy via ethernet backhaul. We would like to put one Multy in the Kitchen (directly below the top floor and sideways from the main ground floor) but it cannot connect directly to the ground floor Multy because of the thickness of the walls.
Would it be possible to connect the top floor study with the kitchen multy via ethernet backhaul?
Also this new one would be the 4th Multy (there is another one in the house that links on its own), is this supported?
Many thanks
#Multy_Apr_2020
Many thanks
#Multy_Apr_2020
Yes, you can connect two satellite nodes with Ethernet cable. Please install them wirelessly first, and move the node to the location, and plug the cable to it.
Please refer to the KB link to build the Ethernet backhaul connection: https://kb.zyxel.com/KB/searchArticle!viewDetail.action?articleOid=017839&lang=EN0 -
Thank you, and can you daisy chain via ethernet backhaul please? i.e. base connects to node 1 via ethernet and node 2 connects to node 1 via ethernet?0
Yes, you can connect first node and second node with Ethernet cable as below topology.
- 164 Beta Program
- 1.7K Nebula
- 86 Nebula Ideas
- 4.7K Security
- 236 Security Ideas
- 1.1K Switch
- 50 Switch Ideas
- 908 WirelessLAN
- 27 WLAN Ideas
- 5.3K Consumer Product
- 172 Service & License
- 294 News and Release
- 65 Security Advisories
- 14 Education Center
- 911 FAQ
- 399 Nebula FAQ
- 249 Security FAQ
- 90 Switch FAQ
- 100 WirelessLAN FAQ
- 18 Consumer Product FAQ
- 55 Service & License FAQ
- 68 About Community
- 51 Security Highlight
FAQ
