Zyxel gs1900-24E CLI Configuration
MrBee
MrBee Posts: 4 image  Freshman Member
edited August 2022 in Switch
Hello
I Have "Zyxel gs1900-24E" and yesterday i have this Configuration:
! System Description: ZyXEL GS1900-24E Switch
! System Version: v1.00.41258
! System Name: Switch
I have found the way to enable Telnet for changing Configuration with Client.
So all was fine.
Then i make Update :-(
Now i have this Configuration:
! Revision: A1
! Serial Number: S140H25000373
! MAC Address Range: 5C:F4:AB:C7:D0:BB - 5C:F4:AB:C7:D0:D3
! Boot Version: V1.00 | 07/25/2013
! Firmware Version: V2.30(AAHK.0) | 12/14/2016
And now i can's configure the Switch with CLI, de Auth-Level was wrong
so i cant use Configure Interface or ele "configure" command and many else.
Can you give mi the Firware for it?
Or what is the Wrong thing about this Mistake ??
Thanks Erwin
#Biz_Oct_2019
  • Kim
    Kim Posts: 37 image  Freshman Member
  • MrBee
    I want to configure the switch with batch command
    I want to create a port1_on.bat or port2_on.bat file and so on...
    I have 5 devices with the same IP address and I have to configure them.
    Now I have five physical switches.
    I first turn one and the others, two to five off. then I configure the first device
    when the first device makes a restart, then I switch the first off and the second on, then I configure the second device and so on.
    I can configure the devices with telnet, now I want a batch process that combines all of this.
    Port 1 on
    upload Configurarion to device 1 with telnet
    Restart device 1
    Port 1 off
    Port 2 on
    upload Configurarion to device 2 with telnet
    Restart device 2
    Port 1 off
    and so on
    I would like to be able to switch the switch ports on / off via Telnet
    or at least change the IP address of each port, the Telnet program will only ever find one of the devices.
    All devices initially have the same IP address.
    There is confusion when everyone is hooked up.
    I want to get away from the mechanical switch
    I need BAtch / cli command for that
  • Zyxel_Derrick
    Zyxel_Derrick Posts: 126 image  Zyxel Employee
    Hi @MrBee
    GS1900 series is a smart managed switch which does not support CLI command to configure.
    It only supports Web GUI.
    If you want to change the IP address without plugging in and out switches for several times, I suggest you downloading ZON utility.
    It can scan zyxel's device and you can do some adjustments within a window.
    Please download it in the link below
    https://www.zyxel.com/products_services/Zyxel-ONE-Network-Utility-ZON-Utility/
    Also, this forum is for home device.
    For GS1900 series, you can go to our biz forum to ask question for further help.
    https://businessforum.zyxel.com/categories/switch
    Best regards,
    Zyxel_Derrick
  • MrBee
  • Zyxel_Lucious
    Zyxel_Lucious Posts: 282 image  Zyxel Employee
    Zyxel Certified Network Engineer Level 2 - Switch Zyxel Certified Network Engineer Level 2 - Nebula Zyxel Certified Network Engineer Level 1 - Nebula 25 Answers
    edited June 2020
    @MrBee
    Check firewall setting in your windows, you must disable firewall to make ZON utility work.
    Zyxel_Lucious
  • MrBee
    ok, Firewall disable, that is bad and not possible in this environment.
    I know the switch's fixed IP address, can I use it without a network scan?
    or teh MAC Adress?
    And, I have installed a second network card only and especially for this switch.
    Can i select with which network card ZON can access the switch?
  • Zyxel_Lucious
    @MrBee
    1.
    Instead of shutting down whole firewall, you can specifically allow ZON in Windows firewall.
    And please make sure there is no other application using TFTP service at the moment.
    2. Yes, in ZON utility you can choose the network adapter to use.
