Bad transfer rate of video stream via WAN [NAS 326]
2»
  • 0101OSX
    0101OSX Posts: 13  Freshman Member
    yes, using the wifi in my home Network, no problem
  • 0101OSX
    there aren't solution?
  • 0101OSX
    anyone?
  • Sakura_T
    Sakura_T Posts: 101
    It's working fine in your WIFI home network fine, which means this is not NAS issue.
    You should consult with your mobile network ISP.
  • Denny
    Denny Posts: 1
    I think you should replace it with a TV streaming Mobdro app, then you can stream it from your phone to any device.
  • 0101OSX
    I realized. I thought that could improve the situation. I'll keep like now. Thank you the same
