NAS326 - Don't enter in sleeping mode
Giacominio
for the problem in title i have follow this discussion https://homeforum.zyxel.com/discussion/comment/3722#Comment_3722 but without success.
I have tried to make hard reset. Nothing
Leave NAS without LAN cable after hard reset. nothing
Also without LAN cable, i ear the hdd in write/read "movement". I suppose it is the reason for non going in sleeping mode
Any ideas?
Please help me.
Thank you
Any ideas?
Please help me.
Thank you
#NAS_Jun_2020
What does the LED of front panel show? always blink or steady on?
And, what is your setting about sleeping mode on NAS?0 -
Hi Kim
Leds blinking during normally use.
During "sleeping mode test" the leds are steady on.
Before unplug net cable i have screenshot this:
I have forgot to screen shotting the "Apps Page" but confirm you that any app are enabled.
Unfortunally, after 20 minutes powered on and net cable unplugged, nas not entry in sleep mode0 -
When the NAS enters in sleeping mode, if the "Enable Sleeping HDD LED Blinking" is check (as in your picture), then the LEDS slow blinkings in correspondence with which drive is in sleep mode.
System LED will continue on steady on, only the HDD1 and HDD2 will do slow blinkings.0 -
https://kb.zyxel.com/KB/searchArticle!viewDetail.action?articleOid=014756&lang=EN
You can refer to this article. I think it is worth to give it a try
@MRisco
my problem isn't leds blinkin or not.
my problem is the HHDs not stop running. Every 20/30 seconds i ear sound like /read/write operation. Ever. Also whit net cable unplugged and setting like scrshoot i have posted0 -
My 'Tweaks' package, (installable when you have installed MetaRepository), has an option to log the disk activity, and maybe that can tell which process is responsible.
@Mijzelf
i have just that.
Php cannot disable.
It is essential for web access to nas326?
I have already reset nas pushing back button over 10 seconds. Nothing
Up.....0
The package is AFAIK only needed for Wordpress. The firmware doesn't need it for it's basic functions.
- 164 Beta Program
- 1.7K Nebula
- 86 Nebula Ideas
- 4.7K Security
- 236 Security Ideas
- 1.1K Switch
- 50 Switch Ideas
- 908 WirelessLAN
- 27 WLAN Ideas
- 5.3K Consumer Product
- 172 Service & License
- 294 News and Release
- 65 Security Advisories
- 14 Education Center
- 911 FAQ
- 399 Nebula FAQ
- 249 Security FAQ
- 90 Switch FAQ
- 100 WirelessLAN FAQ
- 18 Consumer Product FAQ
- 55 Service & License FAQ
- 68 About Community
- 51 Security Highlight
FAQ
