Multy Mini as a third node
simritdave
Newbie here with probably a simple question. My hub/incoming router is at one end of my property, to this I have connected my primary Multy X.
I have successfully connected Multy X 2 wirelessly to the primary. I now want to
connect a mini in my workshop at the other end of the line to complete my coverage.
I would like to do that by wirelessly connecting to Multy X 2 However hard I try, I can’t work it out.
So to recap Primary connected to hub With Ethernet cable and working, secondary connected to primary wirelessly and working. I want to connect a third in line Multy mini By wireless to secondary. How do I do that please?
I am a newbie, I’m a bit of a technophobe so please use words of few syllables and not lots of acronyms.
Many thanks in advance the help I desperately need.
I just did this an hour ago!I purchased an additional multi x and got a free mini.I connected the Multi X in the garage simply swapping it for an old gigabit switch so it was connected by ethernet cable to the rest of the network. I then used the App on my phone and took the option to "add Multi" and gave it a name. Be patient it can take a few minutes.I then took the mini down the garden and plugged it into the mains and repeated the process.Everything found itself, the two new devices downloaded new firmware.Thats it really.I now have 4 Multi's and a Billion Router, which also has WifI so I have 5 access points.0
I figured it, thanks. I needed to flick the daisy chain option to avoid the mini trying to go back to base. Its connected throUgh node 2 now which is how I wanted it.Thanks for your comment though.0
- 588 USG FLEX H Series
- 477 News and Release
