Does Multy X AC3000 support Ethernet Backhaul?
shayanitalia
I want to know if Ethernet Backhaul Setup is supported on the Multy X AC3000 system and what the maximum Wifi Speed is on the 5 GHz channel across a 1gbps Internet connection. So basically if I connect a CAT 7 cable from my main Multy X Model (GIGA LAN OUTPUT) to my Multy X WAN port, will the ethernet backhaul system work by giving a much more rock solid connection.
#Multy_June_2020
#Multy_June_2020
Dear Sir,
Multy X has a dedicated band for backhaul connection, and the maximum rate is 1733Mbps.
However, 1733Mbps is a theory rate, Actual data transfer rates may vary from network conditions including: distance, network traffics, building site material/construction, interference from other wireless devices and other adverse factors.
Multy X Support Ethernet backhaul connection, please refer to the link.
https://kb.zyxel.com/KB/searchArticle!viewDetail.action?articleOid=017839&lang=EN
The Ethernet backhaul will provide much stable connection for your Extender Multy.
Best Regards,
Eric0 -
This doesn’t answer my question:
1. does Multy super Ethernet backhaul?
2. What is the fastest Wi-Fi speed one can get (not wireless backhaul) on the 5Ghz channel across a 1gbps connection!
Please READ before you answer.
thanks0 -
Maybe you should read the answer? I see the answer on both questions.
1. Yes
2. 866Mbps0
- 164 Beta Program
- 1.7K Nebula
- 86 Nebula Ideas
- 4.7K Security
- 236 Security Ideas
- 1.1K Switch
- 50 Switch Ideas
- 907 WirelessLAN
- 27 WLAN Ideas
- 5.3K Consumer Product
- 172 Service & License
- 294 News and Release
- 65 Security Advisories
- 14 Education Center
- 911 FAQ
- 399 Nebula FAQ
- 249 Security FAQ
- 90 Switch FAQ
- 100 WirelessLAN FAQ
- 18 Consumer Product FAQ
- 55 Service & License FAQ
- 68 About Community
- 51 Security Highlight
FAQ
