NFS server broken (possible RPC issue)
t23
t23 Posts: 8
First Anniversary
edited July 2020 in Personal Cloud Storage
Using the ABAG.5 firmware on a NAS542, i installed NFS 1.3.0zypkg007 and added a share. This could not be mounted - macOS gave the error "This file server will not allow any additional users to log on", both when using v4 and v3.
So, i ssh'ed into the box, and found the problem is much stranger:
admin@542:/i-data/xxxxxxxx/.PKG/NFS/bin$ ./showmount -e
clnt_create: RPC: Port mapper failure - Unable to receive: errno 111 (Connection refused)
admin@542:/i-data/xxxxxxxx/.PKG/NFS/bin$ ./rpcinfo -p
No remote programs registered.
admin@542:~$ netstat -an | grep 2049
tcp        0      0 0.0.0.0:2049            0.0.0.0:*               LISTEN
udp        0      0 0.0.0.0:2049            0.0.0.0:*
But lsof (run as root) cannot tell me what process is actually attached to port 2049 (could imagine it's a kernel module then).
rpcbind, rpc.mountd and rpc.statd are all running.
Anybody have any idea what is going on and how to fix it? Thanks in advance!
#NAS_June_2020
  • Kim
    Kim Posts: 37  Freshman Member
    I googled "This file server will not allow any additional users to log on" on the Internet and found this: https://discussions.apple.com/thread/4227674?page=1 Hope it can help.
  • HMMZ
    HMMZ Posts: 5  Freshman Member
    I have ran the same rpcinfo -p on a nfs server I have and got the following.
    When running it on the nfs server:
    $ rpcinfo -p
       program vers proto   port  service
        100000    4   tcp    111  portmapper
        100000    3   tcp    111  portmapper
        100000    2   tcp    111  portmapper
        100000    4   udp    111  portmapper
        100000    3   udp    111  portmapper
        100000    2   udp    111  portmapper
        100005    1   udp  20048  mountd
        100005    1   tcp  20048  mountd
        100024    1   udp  58497  status
        100024    1   tcp  53218  status
        100005    2   udp  20048  mountd
        100005    2   tcp  20048  mountd
        100005    3   udp  20048  mountd
        100005    3   tcp  20048  mountd
        100003    3   tcp   2049  nfs
        100003    4   tcp   2049  nfs
        100227    3   tcp   2049  nfs_acl
        100003    3   udp   2049  nfs
        100003    4   udp   2049  nfs
        100227    3   udp   2049  nfs_acl
        100021    1   udp  57844  nlockmgr
        100021    3   udp  57844  nlockmgr
        100021    4   udp  57844  nlockmgr
        100021    1   tcp  37180  nlockmgr
        100021    3   tcp  37180  nlockmgr
        100021    4   tcp  37180  nlockmgr
    Running the same command against the nfs server host from other host:
    rpcinfo -p nfs_server_ip_address
    Probably as long as you don't see the same there might be services not running, like rpcbind....
    All this just in case you didn't figure it out by yourself.
  • t23
    t23 Posts: 8
    First Anniversary
    It gets more hairy. After a reboot, nfs works - until you disable and reenable it from the control panel, then it reverts to the originally described behaviour.
    Restarting as root on the NAS itself makes no difference.
    Any other ideas? :) Thanks so far, btw!
  • HMMZ
    Hi t23,
    Facts:
    - Reboot - the nfs service is running.
    - Changind the state of the nfs service via web interface practically disables it and it reamins so regardless of further actions.
    I think that looking through all avaiable logs  would help, given the fact you can login to it via ssh and elevate to root your rights.
    Identify how the service(s) are started - for example, as root, run:
    a. systemctl list-unit-files
    or
    b. service nfsd status
    If a. then continue with
    systemctl list-unit-files | grep nfs
    Make note of the output and use it in the following command
    systemctl status service_from_above -l
    This will show you the status of the service.
    systemctl stop service_from_above
    to stop service
    systemctl start service_from_above
    to start service
    More info
    The goal, I understand, is to identify the correct command to start/stop the nfs service.
    Otherwise, if you only want the service to run, just reboot and not act upon it from the web interface.
  • Mijzelf
    Mijzelf Posts: 2,906  Guru Member
    The NAS doesn't run systemd, so systemctl doesn't work/exist on a 542. To stop/start a package, you'll have to execute
    /i-data/sysvol/.PKG/<packagename>/etc/init.d/<packagename> [startup|shutdown]
    The package name in this case is NFS. so the start command is
    /i-data/sysvol/.PKG/NFS/etc/init.d/NFS startup
    There is no status command.
  • t23
    t23 Posts: 8
    First Anniversary
    Correct, the NAS542 uses init scripts. Stopping and starting from the nfs package's script gives the same results as disabling and reenabling from the web interface (most likely uses the same script), i.e. that all portmapper services are completely frozen and/or simply not there.
    Right - not really a solution, but best workaround for sure.
  • Mijzelf
    Is it possible that there are connections on NFS when you restart it, causing the daemons to 'stick'?
  • t23
    t23 Posts: 8
    First Anniversary
    Nopes - i get your way of thinking, but that is not the case.
