NBG6817 - WAN disappears
Hi @Runner17 ,
Sorry for any inconvenience. We are checking the detail and if there's any solution for fixing this issue, I'll update for you asap.
Thanks.0 -
You can remote access your NBG6817 via SSH or Telnet. and check if the daemon of ppp is still up or down when it didn't receive WAN IP.
Can u provide the result of commend, ps | grep pppd and ps | grep netifd?
try below commend when your PPPoE cannot get the IP, and after you click "Apply" on WAN Status Page.
Normally, the result will have two lines, which means the daemon is still up.root@NBG6817:~# ps | grep pppd 21149 root 1460 S /usr/sbin/pppd nodetach ipparam wan ifname pppoe-wan nodefaultroute usepeerdns maxfail 1 user XXXXXXX@XXXXX.net password xxxxxxx ip-up-scr 31925 root 1148 S grep pppd
root@NBG6817:~# ps | grep netifd 18079 root 1232 S /sbin/netifd 32097 root 1148 R grep netifd
Hi @Runner17 ,
Would you PM me your configuration? We'll check it and if you are willing to help to capture the logs again, please click 'Apply' in the WAN setting page and capture the log to us before reboot the AP.
Thanks.0 -
PeterK,Result if following, pppd is not present.
root@NBG6817:~# ps | grep pppd19661 root 1148 S grep pppdroot@NBG6817:~# ps | grep netifd2365 root 1224 S /sbin/netifd20284 root 1148 S grep netifdroot@NBG6817:~#After clicking "Apply" on WAN settings page it appears, I see my PPPoE username and password in pppd command line. However, Internet does not become available until reboot.0 -
Looks like it's quite rare issue.
But for those who will see same issue will write my solution here.
I just uploaded OpenWRT firmware to device. Full file name is "openwrt-19.07.3-ipq806x-generic-zyxel_nbg6817-squashfs-factory.bin", can be uploaded via WEB interfaces in the same way as Zyxel firmware.
Now uptime of my router is 1 week, which was not even once reached with Zyxel firmware during several months.
As additional bonuses I got:
1) crontab in the UI (missing functionality in Zyxel firmware)
2) control of startup services in UI (missing in Zyxel FW as well)
3) flexible LED control (Zyxel FW has only ON/OFF option for all LEDs)
4) network activity graphs without suspicious functionality (for unknown reason in Zyxel fw it's only possible with enabled StreamBoost)
5) better security. I's possible to disable password SSH auth and force key based auth. Standard feature for any device with SSH, however, I do not remember such option in Zyxel UI.
What I will miss:
1) Nice UI. Comparing to Zyxel UI, Openwrt looks little be ugly
2) ..maybe something else. I did not found info what are differences between official OpenWRT and Zyxel firmware (which is some kind of OpenWRT as well), apart from WEB interface and StreamBoost.
Special Thanks to @Zyxel_Eric and @Zyxel_Freda for their efforts!
- 397 Beta Program
- 2.1K Nebula
- 117 Nebula Ideas
- 5.1K Security
- 87 USG FLEX H Series
- 247 Security Ideas
- 1.3K Switch
- 69 Switch Ideas
- 916 WirelessLAN
- 34 WLAN Ideas
- 5.9K Consumer Product
- 211 Service & License
- 337 News and Release
- 71 Security Advisories
- 21 Education Center
- 2K FAQ
- 913 Nebula FAQ
- 421 Security FAQ
- 237 Switch FAQ
- 207 WirelessLAN FAQ
- 46 Consumer Product FAQ
- 139 Service & License FAQ
- 72 About Community
- 62 Security Highlight
